5.3 truck heads
Old Dec 10, 2001 | 10:18 PM
BYBYC5's Avatar
*Bad Trader*
Default 5.3 truck heads
this may have been asked befor but i dont remember the answer, can these heads be used with no problem (provided i get good springs) on my cammed motor (563 lift) i know my comp will be around 11.1 but thats good <img src="images/icons/smile.gif" border="0"> i just want to know if anyone eles is doing it? <img src="graemlins/fluffy.gif" border="0" alt="[Fluffy]" />
Old Dec 11, 2001 | 08:14 AM
BYBYC5's Avatar
*Bad Trader*
Default Re: 5.3 truck heads
TTT please or point me in the right direction <img src="graemlins/gr_punch.gif" border="0" alt="[fight]" />
Old Dec 11, 2001 | 08:20 AM
ws6rufus's Avatar
They will work just fine. You are planning on having them ported or at-least having larger valves installed correct? 5.3l & 4.8l heads have smaller valves than 5.7l heads which will more than offset the extra compression you obtain from them.
Eric
Old Dec 11, 2001 | 11:39 AM
LEO's Avatar
LEO
I've got a set of MTI stage 2 (5.3l) truck heads on my car with their dual valve springs - the only way MTI sells them.
In stock form the 5.7l has a lager intake valve then the 5.3l head, but once they worked on they can accept the same size valves. Therefore you get the benefit of the half point more compression.
I am very satisfied with my set up from MTI. I normally run 11.90's @ 118-120 on Nitto DR and dyno 420 rwhp running with cut out closed.
Hope this helps.
[ December 11, 2001: Message edited by: LEO ]</p>
