Octane booster!! What do you use?
As far as alternative fuels go, I was thinking about mentioning Nitropropane and Propylene Oxide, but you beat me to it. As you mentioned, Nitromethane does not readily mix with gasoline, it mixes with Methanol. However, you can use an ester like amyl acetate to get the Nitromethane to mix with gas. Nitropropane would be the better choice though since it readily mixes with gasoline. It is also interesting to note that nitro-parrafins, like Nitropropane and Nitromethane, drive down the octane of the resulting mixed fuel blend. They also contain enough of their own oxygen, that in pure forms, they can act as a mono-propellant, thus needing no added oxidizer like air to burn.
[ December 12, 2001: Message edited by: 2quick4u ]</p>
new to the board
Travis
California gas is 91 octane at the pump.. Now I am trying to figure out how to get that up to 100 octane using both Xylene and Toluene. I'm lost on figuring this out.. Please explain how to do the eqaution in terms my simple mind can understand. I'm not a rocket scientist.. Thanks guys..
The formula is (Gallons of one fuel x Octane)+(Gallons of other fuel x Octane). Then divide the answer by how many total gallons. I started off with 10 gallons of 91 and 5 of 116.5 (Xylene) and ended up over 100 octane, so I went back and moved the numbers around some. Hope this is broken down far enough, I'm not too good of a teacher <img src="gr_sad.gif" border="0">
(9.5 x 91) + (5.5 x 116.5) is the (gallons times octane) + (gallons times xylene)
Divide all that by 15, because 9.5+5.5 is 15 gallons. Or you can divide by whatever amount the gallons add to. That should yeild 100.4 octane.
edit - seems that turbo buick page says xylene is 117 octane, that would mess my numbers up.
J.
[ December 13, 2001: Message edited by: Crazyquik ]</p>
Or if toulene only comes in 5 gallon jugs, mix 5 gallons of toulene with 8 gallons of 91 to get 99.8 octane.
J.
Tables are set up so you input:
Gas you are using (Octane)
Price you pay per Gallon.
how many gallons of gas to additive
Then it tells you:
Combined octane rating
% of mixture
Cost per Gallon
If someone wants to post it I can e-mail it to them. It might be helpfull to others..
User puts in:
Gal of gas
Gal of Xylene/Toluene
Rated pump octane
Cost of Pump gas and cost of Xylene/Toluene
Spreadsheet tells:
Octane level
% of mixture
Total gallons
total cost
<strong>I put together a spreadsheet for everyones use. If someone would like to post it, I will e-mail it to them.
User puts in:
Gal of gas
Rated pump octane
Spreadsheet tells:
Octane level
% of mixture
Total gallons
total cost</strong><hr></blockquote>
Here ya go
http://www.slowcar.net/shared/octanechart.xls
chris
BTW Chris, do you still have your spreadsheet for rod length up? I thought I had saved it but evidently not. Anyone else have any cool spreadsheets like this to share? I've got the one about LS1 displacement combinations.
J. <img src="graemlins/gr_chug.gif" border="0" alt="[chug]" />
this is one I did - shows you the effect that r/s lengths will have on the piston (instantaneous velocity, acceleration, jerk, etc.). You can just change the first value in each column and it will change the rest.
http://www.slowcar.net/shared/pistonmotion.xls
also found this one floating around awhile ago, and snapped it up.
http://www.slowcar.net/shared/o2_volts.xls
http://www.slowcar.net/shared/jlups/pw_fuel_rate.zip
http://www.slowcar.net/shared/jlups/...fr_wb_calc.zip
These are a couple John Lamb worked up specifically for aid with LT1 Edit tuning.
you can browse most of my misc files at
http://shared.slowcar.net
Dangerous to skin, eyes, heart, kidney, blood,lungs, etc,etc, and cancer causing.
Also mmh will even react with air, it wont flash, but the temeperature in the area of a small leak (couple ounces) will bring the temperature up to 20-30 deg F. Its real good cleaner though, your engine if it survives will be the cleaned you have ever seen.
Now the oxidizer (n204) will destroy any carbon steel quickly, plastics (instantly).
Great stuff to work with, we spend a long time in little blue suits.
Gary
Oh yeah!!!!!
Octane boosters
They will eat up some plastics so be careful.
And here is an MSDS (Material Safety Data Sheet) for Para-Xylene, other aromatics will be similar.
MSDS
There are different types of xylene: Para-xylene, ortho-xylene, & meta-xylene. Octane numbers will differ slightly. I think para- is the highest but don't hold me to that one.
Hope some of this helps,
Les
I was wondering the same thing. It looks like the TR guys are using a lubricant (WD40, Marvel Mystery Oil, etc...) in addition to the alcohol. Further, they are injecting the mixture from an independent tank/resevoir. We, on the other hand, are putting it in the tank and running it through our entire fuel system, including the injectors. Would this have any detrimental effect on our fuel system?
