Engine Guys HELP! Spun Bearings in the 6.0L
Old Dec 12, 2001 | 09:33 AM
Jason 98 TA's Avatar
LS1Tech Premium Sponsor
Default Engine Guys HELP! Spun Bearings in the 6.0L
Guys take a look at these pics, the so called "great condition" motor has more spun bearings than not <img src="gr_sad.gif" border="0"> The thrust bearing is thrasted and it messed up the crank <img src="gr_sad.gif" border="0">
Does anyone know if they make undersized bearings for a crank that has been cut.
Here are the images of the bearings.
http://bam405.ba.ttu.edu/~jmangum/1.jpg
http://bam405.ba.ttu.edu/~jmangum/2.jpg <img src="graemlins/fluffy.gif" border="0" alt="[Fluffy]" /> <img src="graemlins/fluffy.gif" border="0" alt="[Fluffy]" />
__________________
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
Old Dec 12, 2001 | 10:05 AM
Trevor @ Texas Speed & Perf.'s Avatar
Active Streak: 30 Days
Active Streak: 60 Days
Default Re: Engine Guys HELP! Spun Bearings in the 6.0L
OUCH I think the "honest" guy in Oklahoma that sold you the 6.0L needs a little phone call. <img src="gr_images/icons/mad.gif" border="0"> I'd even be up for a visit. <img src="graemlins/gr_guns.gif" border="0" alt="[guns]" />
<img src="graemlins/gr_angel.gif" border="0" alt="[angel]" />
__________________
Old Dec 12, 2001 | 10:46 AM
Reckless's Avatar
Super Moderator
Sheesh! Those bearings actually look better than some I've taken out of my car. Just got my crank back, so get the crabk turned and make sure the caps are true also. Last time I didn't take the time to ensure the caps were true, so I munched the bearings again. Had to have the mains align honed, cut the crank journals .010 under, and install 10-under bearings. Yes they are available from just about anywhere. The rod bearings are standard part number for SB Chevy if you need them. Just go the Carparts.com and search their site for the part numbers. Or you could call our new sponsor, ARE, and get the bearings from them.
Old Dec 12, 2001 | 02:06 PM
Got it <img src="gr_stretch.gif" border="0">
Jason
__________________
Jason
2005 Twin Turbo C6
Old Dec 12, 2001 | 04:21 PM
Crank is getting cut right now <img src="gr_stretch.gif" border="0">
Jason
__________________
Jason
2005 Twin Turbo C6
