Need part number for shortbelt mod ASAP
Old Dec 12, 2001 | 07:39 PM
Skelton's Avatar
Default Re: Need part number for shortbelt mod ASAP
Chris, that would be a gates # K060512. It fits like a charm and allows the water pump to slip just a bit at high rpms for some extra top end hp without any cooling issues. There is 1 bolt in the alternator you will need to remove. You will easily see what I mean. Later.
Old Dec 13, 2001 | 12:00 AM
CHRISPY's Avatar
Default Need part number for shortbelt mod ASAP
Hi guys,
I need the part number for the shortbelt for bypassing power steering when you have the ASP crank and UD pulley setup.
Thanks again,
Chris
Old Dec 13, 2001 | 09:16 AM
CHRISPY's Avatar
excellent thank you sir <img src="gr_stretch.gif" border="0">
That is for the ASP crank AND Alt UD pully setup right?
Cheers!
Chris
Old Dec 13, 2001 | 09:22 AM
Skelton's Avatar
Ooops. I gave you the part # without the ud pulley. I would guess you would need a 1-2 inch shorter belt. Sorry about that.
Old Dec 13, 2001 | 09:56 AM
CHRISPY's Avatar
ahh ok thanks <img src="gr_stretch.gif" border="0">
Chris
Old Dec 13, 2001 | 01:05 PM
MechMan's Avatar
TTT
I could use the part# to
I have the ASP crank and alt. pullies
