A/F gage help...
Old Dec 13, 2001 | 08:21 AM
RPM WS6's Avatar
LS1Tech Administrator
Community Influencer
Default A/F gage help...
Where do you guys tap in for this? We were trying to install one of these last night on an ’02 LS1. The instructions said to tap into the O2 circuit, but looking at Helms each bank and each sensor has it’s own lead. Which one do you use? Can you just splice into the wire at the sensor? B1 or B2? And how do you tell the heater wire from the sig wire? Helms wasn’t very helpful in that area...
Old Dec 13, 2001 | 08:33 AM
BIGBOS's Avatar
Default Re: A/F gage help...
Call izzo and pick up one of the o2 wire plug in things...
Its 18 bucks....
Just tell him you are trying to do an install and he will reccomend the plug in..
<img src="gr_images/icons/cool.gif" border="0">
Old Dec 13, 2001 | 08:53 AM
RPM WS6's Avatar
Thanks Brian <img src="gr_stretch.gif" border="0">
But the guy who owns this car is trying to spend no more money on this if possible. I know it’s only $18 but he’s shooting for $0... LOL!
It’s not for my car, so the choice is obviously his, but is there any way to do this without buying anything for it? Can you just splice into the O2 line? I know Helms warns against “repairing” O2 lines saying that it may degrade the signal, but I know a lot of guys extend them for LT header installs, so would tapping in for this be ok?
The main thing is trying to figure out which is the heater wire and which is the signal, Helms didn’t say...
Old Dec 13, 2001 | 01:00 PM
Pro Stock John's Avatar
LS1Tech Co-Founder
We used the signal wire going into the pcm.
Old Dec 13, 2001 | 01:13 PM
ChrisB's Avatar
You should be able to splice in anywhere *after* the O2 plug. From O2 -> plug it's stainless wire, and virtually impossible to solder. If you have a good gassless crimping gun you can do it, but I am guessing you don't. besides, you would have to re-do it ever time you swapped o2's.
if you splice in anywhere after the plug -> computer area it should be copper wire, which you can solder very easily.
Chris
Old Dec 13, 2001 | 01:25 PM
RPM WS6's Avatar
[quote]Originally posted by ChrisB:
<strong>You should be able to splice in anywhere *after* the O2 plug. From O2 -> plug it's stainless wire, and virtually impossible to solder. If you have a good gassless crimping gun you can do it, but I am guessing you don't. besides, you would have to re-do it ever time you swapped o2's.
Chris</strong><hr></blockquote>
Thanks Chris <img src="gr_stretch.gif" border="0">
But which wire is the heater and which is signal? Any easy way of telling?
Old Dec 14, 2001 | 12:36 AM
Jax White TA's Avatar
I used the wires off the PCM for my signal for each A/F gauge. (B1SI, B2S1)
