crank position relearn??!!
Old Dec 15, 2001 | 03:18 PM
Big Mike's Avatar
Default Re: crank position relearn??!!
That's a hard code that can't be cleared with an Autotap. You need to get your hands on a Tech II tool, the ones that the dealers use. That will clear it.
Old Dec 15, 2001 | 03:29 PM
Speartech's Avatar
9 Second Club/LS1TECH Sponsor
That code can not be cleared without going thru the actual re-learn procedure, and that requires a Tech 2. The best way to handle it is for the reprogrammer to disable it; then it's never an issue!
John
Speartech Fuel Injection Systems, Inc.
www.speartech.com
LS1_edit beta user
__________________
91 Z28 LS2 408CI, LS9 Supercharger, LPE GT7 cam, Yank3000, 3450 raceweight.
Latest numbers: 9.71 ET, 141.42 MPH, 1.40 60' , 610 RWHP Mustang Dyno
www.speartech.com
Old Dec 16, 2001 | 12:57 AM
cablebandit's Avatar
Default crank position relearn??!!
I got a new pcm from Ed Wright to exchange with my current programming. Everything is fine except it gave me a "crankshaft position relearn" code. I clear it but it keeps coming back. Anything "I" can do to clear this? The car seems to run perfect otherwise
