GTP Stage II Heads
Old Dec 16, 2001 | 02:02 PM
Jason99T/A's Avatar
I can shift faster than you.
Default Re: GTP Stage II Heads
This is very normal on ported LS1 heads. Just use some red loctite and you will be fine. <img src="gr_stretch.gif" border="0">
Jason
Old Dec 17, 2001 | 12:49 AM
Batmobile/SS's Avatar
Default GTP Stage II Heads
I have some GTP Stage II Heads that are ported enough where the the rocker arm stud is actually visible in the intake port unlike the stock heads. Is this normal ? Any oil control issues if so. Should I use teflon tape or teflon sealant on the rocker studs ?
