HOTCAM is in...trooper mod or drill TB?
Old Dec 16, 2001 | 06:44 PM
TheZman's Avatar
Default HOTCAM is in...trooper mod or drill TB?
It idles fairly well, but will stumble and stall on restart. On cold starts i have to feather the throttle for a few seconds to keep it running. I have only driven the car 100 miles do to weather, should i drill the throttle blade or adjust the idle screw? or leave it alone till the computer "learns" the idle?
Old Dec 16, 2001 | 07:23 PM
V6 Bird's Avatar
Default Re: HOTCAM is in...trooper mod or drill TB?
Do a little bit of both. First the screw than the TB blade.
Old Dec 17, 2001 | 08:07 AM
TheZman's Avatar
Thanks V6BIRD, thats what i was thinking. I just didn't know if one of the mods would work without doing the other. <img src="graemlins/gr_judge.gif" border="0" alt="[judgement]" />
Old Dec 17, 2001 | 11:54 AM
TA_2001's Avatar
For example lid,hotcam,SLP-LT's,cats+exhaust
I have the throttle blade drilled 15/64
I also have a .022" shim ontop of the FACTORY
set idle stop screw.
It works great for me..
Terry
Old Dec 18, 2001 | 12:17 AM
Jared H's Avatar
TA_2001 are you getting a check engine light with your hot cam? TIA JHH <img src="graemlins/camaro.gif" border="0" alt="[Chevrolet]" />
