Loud "clacking" from engine compartment?
Old Dec 17, 2001 | 06:34 PM
Z06Cam's Avatar
Default Loud "clacking" from engine compartment?
Today, I started getting a loud intermittent clacking sound at idle. When I rev up it goes away, but seems like it might be "missing" a little bit. I thought it may be a broken valvespring or a loose rocker arm, so I pulled the valve covers and had a look. The valvesprings appear to be in perfect condition, the rocker arms were still torqued to spec, and the part of the valvestem that I could see appeared ok
After checking that, I put it back together and that sound returned when I started it up.
I'm running a Comp Cam with a duration of 218I/224E, and a gross valve lift of .528I/.535E. I'm using Comp Cams 26915 valvesprings with new OEM retainers, and I've been revving as high as 6700 during the 1/4 mile, although its been over a month since I've been to the track.
Has anyone else had this problem?
Old Dec 17, 2001 | 08:32 PM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
Default Re: Loud "clacking" from engine compartment?
Make sure the belts are on properly.
Could be the tensioner????
Exhaust leak?
Old Dec 17, 2001 | 08:51 PM
Z06Cam's Avatar
Its not the belts or an exhaust leak. This is a loud metal-on-metal clacking sound.
