would this setup pass emissions??
Stage 1 heads, comp cam (212/218 .522/.529 114), and a set of macs with cat y-pipe? I think t should have no problem whatsoever. I just want to be sure.
That setup sounds totally emissions friendly, unless you have visual inspections. Any headers that move the cats to a different location can’t get CARB numbers. Areas that do visual inspections (like Cali) will not pass a car that has exhaust equipment without CARB numbers. Plus, you also aren’t supposed to have after market cats on the car till after it’s 5 years old. But if all you have is the sniffer test, or an I/M240 (dyno) test, then you’ll be fine <img src="gr_stretch.gif" border="0">
