Motor went BOOM! what are my options?
Old Nov 28, 2006 | 11:34 PM
DoesSpeedTurnUon's Avatar
Default Motor went BOOM! what are my options?
Well, kinda... there are pieces of my piston in my muffler tips.
Anyway, i'm looking at my options here.
I'm considering an Iron block, would that throw my z06 off alot as far as weight?
Should i go with an LS2? LS1/6?
Looking to have a good solid amount of power, preferably around 450+ on 243 heads
Something thats going to be very reliable and can take some abuse, yet still drive across country.
What do you guys think? Big displacement? or what?
Old Nov 29, 2006 | 12:29 AM
LSUxBlake's Avatar
I've heard that the Iron blocks are hardly noticeable in F-bodies, but I'd imagine you would feel it more in a Z06.
If I were you, I'd look in to the 402 LS2 strokers. They really aren't much more than the Iron blocks, and if I had a Z06 I'd go for the reduced weight.
Old Nov 29, 2006 | 12:38 AM
I'll do that, i autocross, no dragracing for me. I'm thinking i should stick with an LS1 LS6 so i don't have to change flywheels (i have mclead twin disc clutch and aluminum flywheel) I might just do a 383 LS6. I'm not sure, i wanted to do an LS2 based motor, but i dont know how much is going to have to be changed over not familiar with the conversion
Old Nov 29, 2006 | 01:36 AM
forgedbluess's Avatar
If you do go the 383 route with a ls1 or ls6 you will have to have it re-sleeved as anything over a .010 bore will not be good on stock sleeves.
Old Nov 29, 2006 | 01:40 AM
Would i be better off to re-sleeve my current LS6 block or buy one from say Texas-Speed?
I'd probably do a 402, i just dont know what goes into a conversion from LS1/6 --> LS2
My block right now...
I think (hope) this can be fixed.
Old Nov 29, 2006 | 02:46 AM
Damn you really did some damage and wont be able to use much out of that block at all. I would just do a 402 if i was you to reach that power range you desire and wont take alot to make that power on a 402.
Old Nov 29, 2006 | 04:40 AM
orangeapeel's Avatar
ЯєŧąяĐ Єl¡m¡иąŧøя ™
402 Shortblock and some TFS heads....you will be screamin again in no time!
Old Nov 29, 2006 | 05:29 AM
Quick Carl's Avatar
Man that's some serious damage !! That block looks pretty far gone for re-sleeving. If you are doing autocross and considering re-sleeving a block, I would look at a stock stroke/ big bore combo to get the 396-400". That would handle the sustained high revs better than the longer stroke.
Old Nov 29, 2006 | 12:27 PM
Cop Car's Avatar
iron blocks are 100 lbs more and hundreds less.
if you are going to build another motor i think its stupid to go with anything under a 4.00 inch bore.
Old Nov 29, 2006 | 12:38 PM
LostCauseZ06's Avatar
lol pm me for my take on this whole thing... i daily drive my car... EVERY DAY... i love my 408
Old Nov 29, 2006 | 12:44 PM
98Z28MASS's Avatar
Man what the hell happened to your car? You over rev of what? As for the new SB I dont think you will be dissapointed with the 402 ls2 based stroker, but you could always up the ante and go with one of the new SDPC 427 short blocks or say the L92 416 offered by one of the sponsors.
Old Nov 29, 2006 | 12:49 PM
S1LV3R's Avatar
Looks like all the pistons on that side are oiled down too.
I was under the impression that the strokers were internally balanced, and you could use your existing flywheel?
Old Nov 29, 2006 | 02:22 PM
that is one thing i want to do... use my existing flywheel, i have alot of money in it.
I'm seriously thinking about a fully forged 346, just for simplicity. But.. with a cam. I'd do a 6.0 liter but i am not sure about the wiring things up on it.
Old Nov 29, 2006 | 02:24 PM
there is no wiring things up... its all plug and play, you reuse all your old sensors.
Old Nov 29, 2006 | 02:41 PM
Cop Car's Avatar
why would you do a forged 346 unless you are limited by some sanctioning body? the diffrence in hp that a 408 would make compared to a 346 would be insane
even if i was limited, id go with a bigger bore, smaller stroke
btw stock cranks are good to about 1500 hp
Old Nov 29, 2006 | 02:46 PM
his crank will be thrashed... his engine looks exactly how mine did.. highly doubt it will be usable, nor would you want to use one thats been through trauma
Old Nov 29, 2006 | 02:53 PM
Jason 98 TA's Avatar
LS1Tech Premium Sponsor
Sorry to see it had that much damage
We have several different strokers in stock & ready to go. I think your probably next day shipping from us...
Call Jon or Zach, they can tell you what we have in stock & give you some good pricing on them.
If you send me some additional pics of the heads I'll see if I can fix them up for you. I have a cnc chamber that will clean up most of that chamber damage..
__________________
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
Old Nov 29, 2006 | 02:58 PM
I've got the passengerside off but i can't figure out how to get that damn altenator bracket off the driver side. to get the head out, although its unbolted, they both i think are going to be fine, the passenger side one does need a little bit of work. The driverside from what i could tell, looked like it was ok. May see about having some larger valves put in them, since i'm going to have to replace some valves anyway.
Old Nov 29, 2006 | 03:43 PM
you have to get a low profile wrench and quarter turn the bolt thats hidden behind the power steering pump.. its a bitch.. lol
