Vic Jr/elbow N/a Hp #s
Originally Posted by Nate_Taufer
Why limit yourself to a 90mm TB when you could go with a 105mm unit? You're going custom elbow, might as well take advantage of it.
Nate
Nate
well, if it's on the nitrous setup, then i wouldn't worry too much for the N/A numbers...
i'd like the intake just based on giving a better distribution on spray if you are running a plate system. i had a 200 shot running through a plate on my sheetmetal intake, and the front plugs showed the setup was a bit lean compared to the rears. just a wide open plenum. are you doing a direct port?
