Gaskets needed for Head Install?
Old Nov 29, 2006 | 11:59 AM
pennys58's Avatar
Default Gaskets needed for Head Install?
Just wondering which gaskets and seals I will be needing to do this head install. Oreileys is trying to sell me a package, $165?
I thought i just needed head gaskets, intake gasket, and a water pump gasket? They are saying I need head gaskets, valve cover gaskets, upper and lower intake gaskets, o rings, water pump gasket, and some others that I cant exactly recall???
Old Nov 29, 2006 | 01:16 PM
sidewayz28's Avatar
valve cover gaskets?? all i ordered were some good old head gaskets from SDPC and head bolts... for 80$ im going to reuse my water pump gasket since its brand new and my fast 90 comes with gaskets i think
Old Nov 29, 2006 | 01:38 PM
pennys58's Avatar
Thats what I figured! Thanks.
Old Nov 30, 2006 | 06:23 PM
GuitsBoy's Avatar
You can get GM MLS gaskets for under 30 for the set. You might want new waterpump gaskets and front cover gaskets and a crank seal if your pulling the cam. Youll also need new head bolts.
really, headgaskets and bolts are all you need. Should be under 60...
Old Nov 30, 2006 | 11:06 PM
WS6FTW's Avatar
Headbolts/head gaskets. Are you pulling the cam? If you are, deffiently relpace the crank seal. All of the other gaskets they want you to buy are re-usable.
