NEED help! Needle bearings in oil pan AGAIN!
Old Dec 23, 2001 | 11:27 AM
thefritz1's Avatar
Default NEED help! Needle bearings in oil pan AGAIN!
Hi all I need some desparate help. I purchased my car used (1 owner who my father works with very easy on the car) only problem with the car was that needle bearings were found so the rocker arms were replaced. No problems for 5 or 6 oil changes however with my 2nd oil change today I found 1 single bearing stuck to the drain plug. WTF! fortunately I'm taking the car off the road but what advice do you have for me?! I'm desparate! PS don't even utter the word warranty as I've got 62K on her and warranty is history...PS its a 99' Z28....
Old Dec 23, 2001 | 11:36 AM
Slow Z28's Avatar
Default Re: NEED help! Needle bearings in oil pan AGAIN!
you know it could still be parts that haven't been drained out before. happens sometimes that he magnet isn't strong enough. hopefully nothing else serious is wrong!
Chris
Old Dec 23, 2001 | 11:40 AM
Trevor @ Texas Speed & Perf.'s Avatar
LS1Tech Premium Sponsor
Active Streak: 30 Days
Active Streak: 60 Days
I'd pull the valve covers and check all of the rockers again. It's very possible that it's a bearing left from the original rocker arm that broke.
__________________
Old Dec 23, 2001 | 02:27 PM
thefritz1's Avatar
As easy as that sounds <img src="gr_stretch.gif" border="0"> I must say I'm a newbie is this something that I could do myself...I'll have 3 months since the car is away for the winter...I'm hoping everyone is right...but would would I be looking for once I pull the valve covers...come to think of it anyone have any links on HOW to remove the valve covers? <img src="gr_stretch.gif" border="0"> thanks guys~!
UOTE]Originally posted by Trevor D:
<strong>I'd pull the valve covers and check all of the rockers again. It's very possible that it's a bearing left from the original rocker arm that broke.</strong>[/QUOTE]
Old Dec 23, 2001 | 04:40 PM
ABNRNGR (Aka Dean)'s Avatar
I had about 15k between the first 32 needles and the final 33rd. Just check your rockers again to see if ones going. If you know they pulled out 33 per side of the rocker then you have another going.
Old Dec 24, 2001 | 10:18 AM
thefritz1's Avatar
Will I be causing more damage by driving the car and changing the oil a little more frequently while searching for additional bearings?
thanks!
[quote]Originally posted by Dean:
<strong>I had about 15k between the first 32 needles and the final 33rd. Just check your rockers again to see if ones going. If you know they pulled out 33 per side of the rocker then you have another going.</strong><hr></blockquote>
Old Dec 24, 2001 | 06:50 PM
you won't hurt the car, the needles won't get past the oil pickup screen, so no damage. I found 10-15 of them on the shelves of the head while changing rockers.
