what would u build
Old Dec 24, 2001 | 10:22 PM
gen3man's Avatar
Default what would u build
if u had 2 start from scratch would u build a ls1 or a 6.0liter i cant decide please give pros and cons of both.it will be n/a and run stage 2 heads all other mods are open to suggestions thanx
it is going in my project see signature
[ December 24, 2001: Message edited by: gen3man ]
[ December 25, 2001: Message edited by: gen3man ]</p>
Old Dec 24, 2001 | 10:31 PM
Raughammer's Avatar
D(irecto)r Pepper
Default Re: what would u build
If money is not the limiting factor the bigger motor equally modded will dang near always win as far as performance goes.
Go the 6.0 route.
You wont have to rev it as high and you will make MORE power.
Old Dec 24, 2001 | 10:36 PM
99 Black Bird T/A's Avatar
What he said, plus if money isn't an issue bore the 6.0 out and make it even bigger.
Old Dec 24, 2001 | 10:47 PM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
I run a 6.0 block, bored .060 over, with stage II heads... 2.08/1.60 valves...
With 11.2:1 compression the car has pulled 435rwhp with inadequate fuel pressure we think it will hit 465-470rwhp now. On pump gas.
