is this cam a good choice
Old Jan 25, 2003 | 09:03 PM
work in progress's Avatar
Default is this cam a good choice
I am putting a 2000 ls1 motor out of a c5 in my truck and thought this might be a good cam since I will want my power lower with the weight of the truck.
HYDRAULIC ROLLER, Good idle, excellent low end torque and mid-range horsepower.1800-4800
212°
221°
.510"
.510"
.300"
.300"
116° Sep
112° Int C/L
-06°BTC 38°ABC /
50.5°BBC -9.5°ATC
Old Jan 26, 2003 | 08:27 AM
Default Re: is this cam a good choice
I know there are plenty of peopleon this board that know the answer to this question.
Old Jan 26, 2003 | 10:52 AM
Raughammer's Avatar
D(irecto)r Pepper
If you are running stock exhaust manifolds...
But why would you put so much timing on the exhaust?
John
Old Jan 26, 2003 | 11:02 AM
MyLS1Hauls's Avatar
Personally, I wouldnt use that cam. There is too big of a split between the intake and exhaust durations. Also the LSA is too wide. I'd look into the comp 212/218 114 LSA cam. It also has lift at about .525". See the post in the truck section under my name about a 216/216 XE comp cam in a 5.3L truck. I like to use single pattern cams in LS1, which have the same intake and exhast durations.
Old Jan 26, 2003 | 11:03 AM
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by Raughammer:
<strong> But why would you put so much timing on the exhaust?
John </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Thats why I asked the question? What would be the benefits? What would be a good choice of cam for what I doing?
Old Jan 27, 2003 | 05:58 PM
2001CamaroGuy's Avatar
I vote the TR 220 on a 114 LSA. Its raited at 1500-6500 RPM but I find it had to believe that it would run that high.
As everyone else said, that seems like a lot of durration on the exhaust to me.
