New pushrods or shims ???
<strong>I am doing a 6.0L buildup and am getting the heads milled .030 to raise compression. The 6.0 has a 9.4:1 compression ratio from GM. Now, should I use shims to adjust my rockers or just get new shorter pushrods? Where do I get shims? What size pushrods would I need?</strong><hr></blockquote>
MMS sells shims.
I don't know enuff about the 6.0 block or your cam's base-circle to give advice on the Pushrod length. I'll say this though. I had my heads milled .030 as well (10.7 to 1 on stock block)...I needed 7.350 p-rods.
IMO, I'd use proper length p-rods. Shims will work for .030...but any more than that, and the rocker geometry gets all jacked up.
