What oil do you use?
Old Dec 29, 2001 | 08:36 AM
GOATBOY's Avatar
Default What oil do you use?
What kind of oil & filters do you guys use.
Old Dec 29, 2001 | 09:09 AM
TA_2001's Avatar
Default Re: What oil do you use?
Take a look at the motor oil poll here.
http://ls1info.com/pollBooth.php
Old Dec 29, 2001 | 09:10 AM
Nine Ball's Avatar
LS1Tech Co-Founder
I've had good luck with Castrol GTX 10W-30 myself. I don't buy into the whole synthetics stuff, its too expensive and doesn't really offer any more protection. I spun a rod bearing on my motor when it was stock and I had Mobil-1 in it at the time.
Filter? I just use a Fram or Delco, sometimes a Bosch. Pretty much whatever is available.
Tony
Old Dec 29, 2001 | 11:58 AM
Patman's Avatar
Yikes, don't use a Fram on the expensive motor Tony! Those filters are total junk, they use such cheap internals that most of the time you're running without any filtration at all. Stick with the AC Delcos and you'll never have a problem.
Old Dec 29, 2001 | 01:48 PM
JayLS1-327's Avatar
Royal Purple 10W-30
Old Dec 29, 2001 | 03:07 PM
turbo's Avatar
Can't beat Amzoil, nuff said <img src="gr_stretch.gif" border="0">
Casey
Old Dec 29, 2001 | 03:17 PM
ChrisB's Avatar
I use Royal Purple and an AC-Delco filter
Old Dec 29, 2001 | 06:50 PM
Z2802's Avatar
[quote]Originally posted by Nine Ball:
<strong>I've had good luck with Castrol GTX 10W-30 myself. I don't buy into the whole synthetics stuff, its too expensive and doesn't really offer any more protection. I spun a rod bearing on my motor when it was stock and I had Mobil-1 in it at the time.
Tony</strong><hr></blockquote>
Is there any advantage/disadvantage to running 5w-30 with our Houston temperatures, I'm thinking of switching to it. On cool mornings I have a tapping noise that sounds like a partially collapsed lifter, once the engine is warm the noise goes away. This started after my first oil change, been using 10w-30 since breakin. Any thoughts?
Thanks,
Chris
Old Dec 29, 2001 | 08:23 PM
mitchntx's Avatar
Splain something, Lucy ...
I will never understand why it is people will burn 2, 3, 4, 5, 6 dollar a quart oil, citing, "it's the best" and then compromise on things like suspension components, citing "it's good enough".
Havoline 10W30 every 2500 miles
100s of time slips
2 seasons of AX
500+ miles on a local road course
65K miles
Never had a wrench on the motor or trans. Still running the original clutch!
Old Dec 29, 2001 | 09:12 PM
LS1 JAY's Avatar
Amsoil 10W30 < I live in Florida so no need for 5W30!
[ December 29, 2001: Message edited by: JAY ]</p>
Old Dec 29, 2001 | 09:24 PM
Alssiri's Avatar
I'm using 10w40 Mobil 1 synthetic!! <img src="gr_sad.gif" border="0">
Old Dec 29, 2001 | 09:29 PM
Jat19's Avatar
I use the regular oil at jiffy lude. lol I not planning on 100 passes at 1/4. Six to eight passes for me, thank you, if that. I'll not paying 50 bucks for oil change. I change my oil every 3,000 and I check it once a week too. JMO..
PS: I'll check out that poll later, another good idea.................
Old Dec 30, 2001 | 12:01 AM
LS1powerN20's Avatar
either mobile 1 tri-synthetic or quaker state.
Old Dec 30, 2001 | 12:11 AM
BIGBOS's Avatar
I use Mobil 1 5w30 synthetic...I think when I change it again I will try royal purple for one time...that product seems to be just as good as mobil 1..
Old Dec 30, 2001 | 07:24 AM
Patman's Avatar
[quote]Originally posted by Alssiri:
<strong>I'm using 10w40 Mobil 1 synthetic!! <img src="gr_sad.gif" border="0"> </strong><hr></blockquote>
How is that possible? Mobil 1 doesn't make a 10w40. Even if they did, that viscosity is not recommended by GM and your warranty will be void.
Old Dec 30, 2001 | 08:32 AM
Z2802's Avatar
I have a 2002, what I find amazing is that my owners manual doesn't say jacks$@t about what kind or give specifications of which oil to use, except it has to have some goofy insignia on it. Theoretically, I could put lawnmower oil in it as long as the insignia is on the can. Very disappointing <img src="gr_sad.gif" border="0"> Seems to me, that leaves them wide open for some warranty liability issues.
Old Dec 30, 2001 | 09:03 AM
Big Mike's Avatar
Royal Purple 10W-30
Old Dec 30, 2001 | 11:33 PM
Alssiri's Avatar
Patman.Where i come from (U.A.E) I could'nt find lower vilocity oil(common is 20w50)& the dealer uses non synth too.I'm not worried about warranty cause i got my 99SS from Texas with no oversea's warranty.It get's realy hot here +40c.
[ December 30, 2001: Message edited by: Alssiri ]</p>
Old Dec 30, 2001 | 11:39 PM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
I'm liking 10W40 dino right now. Castrol or whatever is handy.
Old Dec 30, 2001 | 11:43 PM
ChrisB's Avatar
[quote]Originally posted by mitchntx:
<strong>I will never understand why it is people will burn 2, 3, 4, 5, 6 dollar a quart oil, citing, "it's the best" and then compromise on things like suspension components, citing "it's good enough".</strong><hr></blockquote>
And I will never understand why people would skimp on a couple of bucks a quart on motor oil since without a working motor all those fancy suspension parts are useless <img src="gr_images/icons/wink.gif" border="0">
I can afford the oil, it does have better characteristics (whether they make a material difference or not is debateable, but they do have better "stats) - so why not?
Though i think your question was in jest, the answer is of course cashflow. It's easier to spend 20 bucks extra 3 times a year then 400 or whatever once, but all at the same time.
And of course the two "positions" you brought up are neither mutually exclusive nor related. So I have to say it's a bad example.
<img src="gr_stretch.gif" border="0"> <img src="gr_stretch.gif" border="0"> <img src="gr_stretch.gif" border="0">
Chris
