Last minute suggestions on pulling Heads & Cam job?
Old Dec 31, 2001 | 10:08 AM
2000 Camaro SS's Avatar
Default Last minute suggestions on pulling Heads & Cam job?
I am about to install a new Cam, pull my heads to port and polish them are there any last minute suggestions I should know about? Any information that you would like to share with me from your own past experiences that might help me. Thanks.
Old Dec 31, 2001 | 06:22 PM
Default Re: Last minute suggestions on pulling Heads & Cam job?
Anyone?
Old Jan 1, 2002 | 03:44 PM
Quickdraw's Avatar
Buy a slightly longer 16mm bolt for pulling the balancer. The stock length is about 1/4-1/2" shorter than you want IOT pull the pulley completely off. I got one at NAPA for $1.50. I think the size you want is 16mm X 4.5", a 4.25 will do.
Old Jan 1, 2002 | 04:32 PM
jmX's Avatar
jmX
What kind of suggestions do you want? How to install, or what heads/cam to buy?
Old Jan 1, 2002 | 04:45 PM
[quote]Originally posted by jmX:
<strong>What kind of suggestions do you want? How to install, or what heads/cam to buy?</strong><hr></blockquote>
Looking for people that have done the work before and found a trick or two about the job. Like right now (as we speak) I'm doing my clutch. To remove the slave I needed a 10 mil open end wrench. I now know if you use electric tape and tape the open end wrench to a screw driver it is now long enough to reach the 10 mil bolt a lot easier. Suggestions like that. I have the cam and most tools for the port & polish job. Thanks for the help. :-)
Old Jan 1, 2002 | 05:51 PM
jmX's Avatar
jmX
All the tricks I know are on my site in the head install page... http://ls1.fbody.com
Old Jan 1, 2002 | 05:59 PM
JMX
Thank for the link.
