Having no luck with SLP MAF and MAFT?
Old Jan 4, 2002 | 04:52 PM
Reckless's Avatar
Super Moderator
Default Having no luck with SLP MAF and MAFT?
Just started playing with it. LTrims seems quite high at "0" settings, so I started to lean out the base settings. When I get to about 15% lean, the car won't run worth a crap.
--Is there learning time required every time the settings are changed?
--When people say adjust the LTrims to "0" while "cruising", can someone define cruising. Part throttle? 25% throttle? 50% throttle? I notice the LTrims var quite a bit depending on the load.
--When changing settings, do you have to step through them? Or can you jump past a few? Say from 5% to 20%, or will this cause very poor idle.
Old Jan 4, 2002 | 05:03 PM
Reckless's Avatar
Super Moderator
Default Re: Having no luck with SLP MAF and MAFT?
Doh! I think I was doing things backwards! If the LTrims are positive, then I am running LEAN? I should be adding fuel rather than taking it away. No wonder the damn thing won't idle <img src="images/icons/rolleyes.gif" border="0">
Correct me if I'm wrong please. Also bitch slap me.
Old Jan 4, 2002 | 05:15 PM
ABNRNGR (Aka Dean)'s Avatar
now you have it Todd
Old Jan 4, 2002 | 05:18 PM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
I am running -15% base right now otherwise my car loads up. I am seeing 60psi at idle and I have no exhaust backpressure.
Reckless's Avatar
Super Moderator
Thanks Dean....where's my bitch slap?
Old Jan 4, 2002 | 06:25 PM
Diesel's Avatar
I got a bitch slap for you Todd! <img src="gr_grin.gif" border="0"> LOL
Old Jan 4, 2002 | 07:43 PM
Reckless's Avatar
Super Moderator
Thanks Dave....needed that from someone! <img src="graemlins/gr_jest.gif" border="0" alt="[jester]" />
Old Jan 4, 2002 | 07:58 PM
how's going Todd
Old Jan 4, 2002 | 11:20 PM
Reckless's Avatar
Super Moderator
Getting it figured out now <img src="gr_grin.gif" border="0">
