is fuel injector cleaner bad?
Old Jan 4, 2002 | 09:02 PM
Matt Jeschke's Avatar
Default is fuel injector cleaner bad?
Some people tell me it is a must, some people say don't use it period. Whats the truth? thanks for the advice!
Old Jan 4, 2002 | 09:09 PM
1badls1bird's Avatar
Default Re: is fuel injector cleaner bad?
No, it is good, but use the good stuff,like Red-line or the NOS brand. Ocatane booster can fould plugs and those snake oil additives are a big NONO! But fuel system cleaner is fine, you should do it every once in a while IMO.
Old Jan 4, 2002 | 11:09 PM
Steve98Z's Avatar
Clean your injectors individually or buy new ones, if you have build up or gunk in your gas tank, injector cleaner will break it down and send it into your engine.
Old Jan 5, 2002 | 05:02 AM
Patman's Avatar
Ocassional use of injector cleaner is ok, but you should only use it maybe once a year, or twice a year if you do a ton of driving. Anything more than this is overkill and could cause more harm than good. Definitely only use the good stuff, such as the Redline SI-1 stuff, STP, or the stuff with Techron in it.
Old Jan 5, 2002 | 07:32 AM
BudmanY2KTA's Avatar
What about the injector cleaner that attaches to the schrader valve on the fuel rail? You disable the fuel pump and idle the car using the can. Has anyone used this, and if so do you have a part#?
Thanks Rich.
