What TPS voltage=90 degrees?
Old Jan 6, 2002 | 12:34 AM
Bill's Avatar
Default What TPS voltage=90 degrees?
I did a search but only find people reference throttle position angle. I am using version 1.12 of Autotap and can only get the following readings;
Throttle position angle normalized 100%
Throttle postion angle 99.6%
Throttle position sensor A/D 4.4v
These readings are with the pedal pushed all the way open. Its clear to me looking at the blade its not all the way open. I want to start the bump stop mod but don't know what TPS voltage is equivalant to 90 degrees. I know the old version of Autotap must have had it but my laptop won't run on anything but v1.12.
Old Jan 6, 2002 | 12:39 AM
RyanJ's Avatar
SSU Moderator
Default Re: What TPS voltage=90 degrees?
you want 4.6v.
Old Jan 6, 2002 | 08:19 AM
Shaner's Avatar
You can take the TB off and use a square on the front of the TB to see where your at. There's a lot of material that must be removed, just check often and don't go past 90*
When you get it to open just short of 90*, you can put it back on the car and use the A-tap and a file to finish.(use TPS A/D - set it to 4.6)
Old Jan 6, 2002 | 08:40 AM
Patrick G's Avatar
LS1 Tech Administrator
I always used 4.7 volts, but 4.6 is better anyway.
__________________
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2022 Cadillac Escalade 6.2L A10 S&B CAI, Corsa catback.
2023 Corvette 3LT Z51 soon to be modified.
Custom LSX tuning in person or via email press here.
Old Jan 7, 2002 | 08:09 AM
Bill's Avatar
Thanks for the quick replies. Have it set to 4.6v now.
