Doing PCV mod?! --worth it?
Old Jan 6, 2002 | 11:48 AM
thefritz1's Avatar
Default Doing PCV mod?! --worth it?
Hey guys I have all the materials necessary to do the PCV mod (Steve's) and I'm curious if there is a way to check to see if this mod will actually help with my oil consumption problem. --In otherwords is there anything I can check for to see if oil is getting in the intake. PLEASE be as elementary as possible as I'm quite new at this. I CAN say that there was SOME stuff in my throttle body but no TOO MUCH any other ideas?! Thanks guys!
One retarded ls1 owner
Old Jan 6, 2002 | 01:27 PM
LS1JM's Avatar
Default Re: Doing PCV mod?! --worth it?
Have you tryed the new pcv valve yet? <img src="graemlins/camaro.gif" border="0" alt="[Chevrolet]" />
Old Jan 6, 2002 | 02:46 PM
thefritz1's Avatar
NO! Any additional info? I'd love to avoid having a bunch of catch cans and crap in a brand new (to me) car. Could you post or email me additional info. Thefritz11@home.com!
thanks
[quote]Originally posted by LS1JM:
<strong>Have you tryed the new pcv valve yet? <img src="graemlins/camaro.gif" border="0" alt="[Chevrolet]" /> </strong><hr></blockquote>
Old Jan 6, 2002 | 02:49 PM
MelloYellow's Avatar
I prefer the SMH w/o the catch can. The Dual filters are what seems to help the most. I replace them every oil change.
Old Jan 6, 2002 | 04:50 PM
thefritz1's Avatar
So with that mod I'd do the SMH, however, just leave off the portion with the catch can and use the two filters? any other tips folks?!
U guys rawk!
[quote]Originally posted by MelloYellow:
<strong>I prefer the SMH w/o the catch can. The Dual filters are what seems to help the most. I replace them every oil change.</strong><hr></blockquote>
Old Jan 6, 2002 | 05:48 PM
Ya. You can just put a 3/8" vacuum cap where the T goes to the Catch Can to leave yourself flexibility (capped mine like this) or just use an Elbow instead of a T there.
[ January 06, 2002: Message edited by: MelloYellow ]</p>
Old Jan 6, 2002 | 06:40 PM
DanZ28's Avatar
What's that "new" PCV part #?
Old Jan 6, 2002 | 06:54 PM
LS1 Mopar Turbo's Avatar
Mine works great! I change my filters every oil change.
Old Jan 6, 2002 | 08:28 PM
Silent but Violent's Avatar
Dan, its pn#12572717 <img src="gr_stretch.gif" border="0">
Old Jan 6, 2002 | 08:59 PM
LS1JM's Avatar
The new valve fixed my car. My car uses no oil now. <img src="graemlins/fluffy.gif" border="0" alt="[Fluffy]" />
Old Jan 7, 2002 | 12:01 AM
'98 Six Speed's Avatar
Yes, thouroughly clean the line that plugs into the intake and after a week or so, pull the line and it should still be clean and dry.
Old Jan 7, 2002 | 12:29 AM
98blackSS's Avatar
Yeah, I could actually pull mine off and shake it hard against the ground and oil would fly out. Clean the lines out and check later on with a Q-tip or something.
Old Jan 7, 2002 | 12:54 AM
stevenmh's Avatar
You'll probably want to clean the oil off your TB blade while you're at it. You can check it later to see that it stays clean.
Old Jan 7, 2002 | 01:46 PM
mmiller's Avatar
Texas Director
LS1JM,
Did you use just the new PCV valve with the your stock PCV system? You had oil consumption problems with the stock PCV valve and you went to the new PCV valve and it cured your oil consumption? Do you know if GM has a TSB that will replace the stock PCV valve with the new one under warranty?
If you could confirm this I would really appreciate it.
<img src="images/icons/confused.gif" border="0">
Old Jan 7, 2002 | 01:55 PM
Toxic Texan's Avatar
Well I am not using any oil so I won't try anything yet, but does anyone have any pics of before and after of the lines?
Old Jan 7, 2002 | 03:06 PM
LS1JM's Avatar
LS1JM,
All I did was replace the "stock" valve with the new part #. The TSB is for the truck engines only.The valve is only $3.33 list. Joe.. <img src="graemlins/camaro.gif" border="0" alt="[Chevrolet]" />
[ January 07, 2002: Message edited by: LS1JM ]</p>
Old Jan 7, 2002 | 03:20 PM
mmiller's Avatar
Texas Director
Joe,
I just talked to the GM parts dept. a Les Marks Chevrolet in La Porte, Tx. and gave him part# 12572717. The parts guy on the phone said that it was a "fitting". He said that he had no other details and could not offer a better description for the part.
Can you describe what the new PCV valve looks like or post a picture of it? If I order the part exactly by this part number (no letters?) will I get the PCV valve that you are talking about? I asked him if it was a PCV valve and all he could tell me was that it was a fitting.
Thanks for your help. Hopefully you have come across a solution to a real problem for many LS1 cars. <img src="images/icons/confused.gif" border="0">
Old Jan 7, 2002 | 03:42 PM
LS1JM's Avatar
MMiller, it is called a fitting. It looks no different than the normal valve. GM wants to call it a fitting because it is a hollow PCV valve. Have them order you one. Joe..
Old Jan 7, 2002 | 09:35 PM
thefritz1's Avatar
So this new FITTING as we call it will directly replace the PCV valve and should reduce consumption similar to a catch can filter system? Just checking 'cuz I'd like to avoid having to install a system like that in a 20+ thousand dollar car!!!!
Thanks guys just let me know...for 3 bux its worthit!
<strong>MMiller, it is called a fitting. It looks no different than the normal valve. GM wants to call it a fitting because it is a hollow PCV valve. Have them order you one. Joe..</strong><hr></blockquote>
Old Jan 8, 2002 | 08:32 AM
mmiller's Avatar
Texas Director
ttt
