Valvetrain Noise on H/C Motor
<img src="graemlins/z06.gif" border="0" alt="[Z06 Corvette]" />
If the heads were ground any... did you add spacers under the rockers to compensate? (.030, .045, .060)
If all that is correct. A little more noise is normal. But have you sure your set up is correct? If so...all is good and the "noise" is just "music" to compliment the newly installed HP.
Good luck.
Headers will make the valvetrain a bit louder too.
Doug
00 Pontiac
