Finally decided! engine build up on my TA
Old Jan 9, 2002 | 10:44 AM
Joe Prince's Avatar
Default Finally decided! engine build up on my TA
Well, after kicking around some ideas, I have decided to go with a set of ported LS6 heads and a TR 224 cam with my new coated Hooker headers that are going to be here late next week! I used the flow math from Bears heads and it should lay down some serious numbers on the dyno, the track? who knows, I will have to make the correct driveline provisions for it like 4:10's and a REAL clutch! Well, I was going to do a set of LS1 ported heads and a 2002 LS6 cam and decided screw it! I like what I saw on JS's car with that cam, and then the ported LS6 heads at 11.5 - 11.8 compression (don't know yet) should really put it above and beyond what I wanted to begin with. 304 cfm at .550 with 224 cfm max exhaust flow should do the trick. Now all I have to do is find the time to work on it!
Old Jan 9, 2002 | 10:46 AM
CHRISPY's Avatar
Default Re: Finally decided! engine build up on my TA
Sounds great!!! I cant wait to hear how you like the Hookers!
Good luck!
Chris
Old Jan 9, 2002 | 10:51 AM
WS6 TransAm Girl's Avatar
U r gona fly!!! <img src="gr_grin.gif" border="0"> <img src="graemlins/camaro.gif" border="0" alt="[Chevrolet]" />
Old Jan 10, 2002 | 12:09 AM
JS's Avatar
JS
Joe do the mods to the SS instead..
Otherwise a 12 bolt is comming your way real soon along w/a $$$ clutch if u run a stick car..
Either way its gonna run REAL WELL w/your little butt (165lbs.) in the driver seat <img src="gr_grin.gif" border="0">
Good Luck
JS
Old Jan 10, 2002 | 12:30 AM
Ragtop 99's Avatar
11.8 compression <img src="gr_eek2.gif" border="0"> I'm sure you'll be fast.
Good luck. If you don't have the time to port new heads, I know where you can find an excellent set of heads right now. <img src="gr_images/icons/wink.gif" border="0">
Old Jan 10, 2002 | 12:44 AM
Bear's Avatar
Sweet Joe. We can go run sisde by side this season. Can't wait to see it. I hope that OUR setup comes out great. Good luck. <img src="graemlins/formula.gif" border="0" alt="[Pontiac]" />
