How to set Idle and why
Old Jan 9, 2002 | 01:10 PM
Supertrapped's Avatar
Speed freak
Default Re: How to set Idle and why
If you don't...then your car will be idling too low and want to die. Eventually, it will.
Miah
Old Jan 9, 2002 | 01:23 PM
RPM WS6's Avatar
LS1Tech Administrator
Community Influencer
You can raise the idle by turning the idle set screw on the TB, or by way of a custom tune. The problem with turning the set screw is that if you raise it much more than 150rpm or so you will set codes.
Old Jan 9, 2002 | 06:18 PM
TheZman's Avatar
It is very easy to adjust. The screw is a T15 torx. you will need just the small T15 bit, you can't use a screw driver or even the big bit because there is not enough room. I use the small bit with a 1/4 inch open end wrench. tape the bit in the wrench. Mine only needed to be turned about a quarter turn, but that will vary from car to car.
Old Jan 10, 2002 | 12:26 AM
1badmfr's Avatar
Default How to set Idle and why
I always here when you guys are talking about cams that you have to set your idle. How do you do this and why?
