What would the ill affects of this be (PCV mods)
block off the fresh air line from the T-body to the valve cover.
Remove the PCV line from the manifold and plug it.
extend and run the PCV line WITHOUT a PCV valve in it to within one inch of the airfilter.
If you did this the PCV would vent to atmosphere and the fumes would get sucked into the airfilter on the way to the motor. There wouldnt be a vac leak and you wouldn't have to worry about fumes in the car or oil dripping from a valve cover breather on your headers. The vapor from the PCV would get sucked in through the airfilter and not cause a stink. Is there something I am missing here? After WOT and the throttle closes wouldnt the PCV just vent to atmosphere but still get the vapor sucked into the airfilter?
You would have to clean your filter a little more frequently but you wouldnt have to worry about oil consumption. What am I missing or would this work?
Chris.
Instead of the check valve you relocate the line to the filter <img src="gr_stretch.gif" border="0">
hee hee
Chris
The only reason PCVs arent vented to atmosphere is for emissions and the odor of PCV vapor under the hood. If the PCV valve was removed and the open lines were routed to the bottom of the airfilter, then the odors would get sucked into the airfilter. The IATs wouldnt rise considerably when you consider the amount of air being sucked into the motor. There wouldn't be any risk of blowing gaskets as both valvecovers are vented, joined by the Y and placed within one inch of the airfilter (which would suck up the fumes.) With the fresh air line closed off there isnt any worry of introducing a vac leak or unmetered air entering the motor.
Am I missing something in my logic?
Cheers,
Chris
I see what you mean about the vac leak, but I don’t seem to have one <img src="images/icons/confused.gif" border="0"> If there were a vac leak (like when the PCV is disconnected) due to the Metco, then my Ltrims should be at 25% at idle, correct? They aren’t though...they are perfectly normal (0 to 4). I don’t think you’re introducing any significant amount of unmetered air by having a breather in place of the oil fill cap and still keeping a fully intact PCV system? Maybe I’m wrong? <img src="images/icons/confused.gif" border="0">
There wouldnt be any vacuum developed by your system, at part throttle it would not apply the vacuum to crankcase that ring package was engineered for, that doesnt mean it wouldnt be acceptable worth trying IMO. BUT remember pcv contributes to idle speed (its a bypass of air around throttle not thru it) and this would require opening throttle more to get same idle speed.
So the rings are affected by part throttle vaccum from the PCV? That is VERY interesting!
What would the possible ill affects be?
Thanks again,
Chris
I have messed with some of that stuff. Anytime I have run with an open pcv line my idle gets a little more ragged and goes up at least 100 rpms.
PCV's flow at low vacuum conditions, they close at hi vacuum and hi pressure to keep a intake backfire from exploding crankcase fumes! <img src="gr_eek2.gif" border="0">
if so how do you keep or know what flow rate to use, in other words did this raise your idle way up? Also what keeps this from sucking oil into lower port?
LS1 would benefit from this but the more RPM's the more there would be to gain. Food for thought. <img src="graemlins/burnout.gif" border="0" alt="[Burnout]" />
<strong>can some explain the breather in the oil fill cap mod?</strong><hr></blockquote>
A company called Metco (I can’t remember their website though, it’s something like metco-inc.com or something) makes a breather that has a screw in base that goes in place of the oil fill cap. Then a breather pops into that base. This allows you to retain a full factory PCV system, but still vent pressure into the atmosphere enough that the PCV doesn’t seem to suck oil into the intake anymore. I don’t know if the PCV is doing anything at this point, but what’s the lesser of the two evils, oil fouled intake, valves, piston tops, etc., or less PCV operation? I just don’t know, so I’ve been going back a fourth on this setup. But every time I put the breather back in my oil consumption goes away.
