Dry sump???
Can someone please explain what a dry sump oiling system is and how it is differnt from stock.
pros & cons.
I have seen this mentioned, but never an explanation as to what it is.
Thanks, I'm sure I'm not the only one who doesn't know this...
pros & cons.
I can shift faster than you.
Nearly every single production car uses a "wet" sump oiling system. The oil is stored in the oil pan beneath the crankshaft. The oil pump picks up oil from the bottom of the pan with a pump and it is cycled throughout the engine.
In a "dry" sump oiling system, oil is kept in a tank/pan outside of the engine. There are usually 2 pumps that work the system - one takes oil from sump and sends it to the tank and the other takes oil from the tank to distribute to the rest of the engine.
There are a few advantages to dry sump. With a dry sump, you no longer have excess oil around the crankshaft. This oil sticks to the crank and eats HP. Also, in a wet sump system, hard turning/braking (auto-x cars) can cause the oil to puddle on one side of the pan, causing the oil pump pick-up tube to become uncovered. This is a bad thing. LOL
Only major disadvantages would be extra weight. Also, I believe the AC system would have to be removed on the LS1 to mount the external tank/pump,etc. The ASA LS1 motors are using this system with great success.
I just saw this system installed on an LS1 by Futral motorsports on GTS_SS's car. Hopefully we will have some track reports and horsepower #'s soon. You should look at it as a way of taking a task away from the motor and allocating it to an outside source for (hopefully) added power.
I want to click on a normal smiley to end my post but everything is so complex....so =)
