Why would one cylinder run lean?
-Kris
<strong>I had the spark plugs out for inspection today. #2-8 all looked good with a slight brown coating. #1 was clean as a whistle, no discoloration at all. I am thinking that #1 (being white) was running lean. This would explain why the engine feels a little off balance and the slight pinging I hear at low RPMs. Maybe just one cylinder is running lean? What would do this? Is there anything that I can do to check/clean the fuel injectors (now running some used SVO 30# injectors that I bought used from a guy on LS1.com). Any help would be greatly appreciated.
-Kris</strong><hr></blockquote>
If you suspect it's the injectors, but not sure, why don't you swap the injector to another cylinder and see if the problem reoccurs on that cylinder. If so, I would send them to get cleaned up and balanced.
