What do you think of this heads/cam plan?
I was thinking about ARE's S2 heads with 11.2:1 compression, DOUBLE springs, and port them to match the following cam <img src="gr_stretch.gif" border="0">
224/224 114LSA and 600-.610 lift.
That should idle decent in my 360 motor with the 114LSA and 224 duration but make great power with the 600 lift and double springs.
What do you guys think? Do you think a 600 lift cam with double springs can be durable on the street? I think it would give great power while maintaining drivability and emissions concerns.
What are your opinions? Worthwhile to change from my B1 cam and S1 blower ported (9.7:1) heads? Should I just max out my S1's with the 2.02/1.57 valve combo and throw double springs on them?
Cheers,
Chris
edit - he's asking 2800, but I wouldn't offer 2500 if I didn't want it.
[ January 18, 2002: Message edited by: Crazyquik ]</p>
To check this, I would get the head flow data and see what that extra lift is getting for you before making that decision. If it looks that much higher, and you have some really good springs, maybe it will work for you.
If I was to do a hydraulic heads/cam setup, that is what I would do. If you REALLY want to upgrade, how about a solid roller. <img src="gr_tounge.gif" border="0">
[ January 18, 2002: Message edited by: Jason99T/A ]</p>
Will you pass emissions on 11.2 CR?
BTW, Get in on Grots GP if you're going to go this route.
<img src="graemlins/z06.gif" border="0" alt="[Z06 Corvette]" />
