MTI T1 Cam and Nitrous
I now have a T1 cam and love it, but it is not a great cam for nitrous use from what I have been hearing. When I bought the cam from MTI, I told them I was spraying an NX 100 shot, and they said it would work well with the T1, and not to worry. My questions is, how bad is this cam for nitrous use? Is it just not as good as other cams with split pattern, more lobe seperation and exhaust duration? Or does it suck so bad that I would be better off with the stock cam when spraying?
I'm asking this because I would like to spray at the track again, but that would totally suck if I only get 50 RWHP out of a 100 shot because this cam sucks so bad for nitrous use. I'll dyno the car again soon, but want to hear from the people here.
So please speak up from experience, or just opinion if you feel like commenting.
Once again, how much does this cam suck for nitrous use?
(I'm posting this here instead of the nitrous forum because this has much to do with cam selection, and I may get more responses here from the greater level of traffic.)
But, HELL NO, your stock cam will not be better for nitrous than a T1. Please do not assume that the T1 cam will not work with nitrous at all, that is far from the truth. It works just fine on nitrous, and you will probably gain more than 100 rwhp with your 100 shot now.
Besides, you are only running a 100 shot right now, so don't worry about changing to another cam suited better for nitrous. I do not ever recommend "building" a motor designed for nitrous unless you are spraying over a 200 rwhp shot into it. Anything less, then focus on the naturally aspirated power and just consider the nitrous as a "bonus" on top of that.
PS, I ran 11.1 @ 130 mph with heads/T1/120 dry kit on drag radials. Best dyno on nitrous was close to 530 rwhp with the T1 back then.
Brooke also ran mid-10s on nitrous with the T1 about 2 years ago. Was the fastest LS1 on the net back then.
Tony
Now that I have my Cartech clutch in, I'll be making nitrous runs at the track again soon.
