HELP! installed slp longtubes Y pipe banging
Old Jan 20, 2002 | 09:27 PM
highgmc's Avatar
Default HELP! installed slp longtubes Y pipe banging
I just installed my slp longtubes off road y pipe and borla cat back. The y pipe is banging on accelleration and almost instantly the knock sensor must be picking it up and running like crap for a second. any fix for this? makes you mad having spent over $1000 for these headers.
Old Jan 20, 2002 | 09:50 PM
Bad Habit Bird's Avatar
Default Re: HELP! installed slp longtubes Y pipe banging
Go to an exhaust shop and have them heat up the Y-pipe and bend it down some.
Old Jan 21, 2002 | 09:16 AM
RPM WS6's Avatar
LS1Tech Administrator
Community Influencer
Terry, what type of cat-back do you have? I might have an idea of what is banging...
Old Jan 21, 2002 | 09:32 AM
Jake99SS's Avatar
[quote]Originally posted by terry99ta:
I just installed my slp longtubes off road y pipe and borla cat back. <hr></blockquote>
<img src="gr_grin.gif" border="0">
[ January 21, 2002: Message edited by: Jake99SS ]</p>
Old Jan 21, 2002 | 09:44 AM
99 Black Bird T/A's Avatar
Saw this in another thread, thought you might want to see it regarding the banging issue.
[quote]Originally posted by RPM WS6:
[QB]The SLP Y-pipe DOES NOT have fitment issues with SLP subframe connectors. This I can tell you from personal experience with more than one car. It only bangs (if installed WRONG) on the lip of the driveshaft tunnel. Nowhere else that I’ve seen on a few cars with this combo. If the installer knows what he’s doing and tightens everything up back to front this won’t be an issue. This is exactly how we’ve fixed that banging.<hr></blockquote>
Old Jan 21, 2002 | 09:56 AM
RPM WS6's Avatar
This is correct. Start by checking the area where the I-pipe meets the Y-pipe. It will probably be about an 1/8 inch away from the side of where the floor board curves up into the drive shaft tunnel. This is where it almost always bangs. Just loosen the bolts for where the other end of the Y-pipe clamps to the cats/off road pipes, and then loosen the two mounting bolts for the back end of the Y-pipe. Now, using a crow bar or something shove the Y-pipe (at the I-pipe intersection) away from the passenger side of the driveshaft tunnel. Once you have a good deal of clearance, tighten the back bolts first, and then the front clamps. The banging should no longer exist. If you have a cat back (like the loudmouth) where there is any dropping down for a resonator or bullet muffler in the I-pipe, and the I-pipe is not perfectly strait this might be jamming the Y-pipe into that driveshaft tunnel. At that point you can either try and straiten the I-pipe or glue some heat resistant rubber to that part of the tunnel (or both for added protection).
Hope this helps...
Old Jan 21, 2002 | 05:05 PM
BISHOP's Avatar
It could also be banging the floor board where the off road pipe connects to the Y-pipe on the drivers side. This is where mine has been banging.
