slp headers/orange heatshield hose against header
Old Jan 20, 2002 | 09:47 PM
highgmc's Avatar
Default slp headers/orange heatshield hose against header
anyone with the slp longtubes have problems routing the wires on the passenger side? the supplied orange hose it against my header. there seems to be no other way around this other than making the wires longer which I am not trying.
Old Jan 21, 2002 | 04:41 PM
highgmc's Avatar
Default Re: slp headers/orange heatshield hose against header
I read on here somewhere that adding to the wires will casue problems with the computer reading a different resistance???
Old Jan 21, 2002 | 05:29 PM
2000 Camaro SS's Avatar
You do have to use the orange wrap this is the only way to protect the wires. Make sure that it is around the wires very well and try to over lap the orange this so the seem is in the back.
Old Jan 21, 2002 | 08:25 PM
Country Boy's Avatar
Senior Member
Mines been that way for many months now and no problems at all.
Old Jan 21, 2002 | 09:03 PM
Gimp98ss's Avatar
just lenghten the wires about a foot just use approximitly same gauge wire i use 16 gauge worked perfectly. <img src="gr_images/icons/cool.gif" border="0">
Old Jan 21, 2002 | 10:32 PM
Rock's Avatar
Scour the parts stores for WATERPROOF connectors. If moisture gets in there, whoever's got your car 5 years down the road won't be happy.
It's safe to say that miniscule amount of added resisance will hurt far less than shorted (burnt thru) or corroded (high ohms) wire.
And use exactly the same size wire. That way it fits in the same size split loom and looks factory. I beleive most wiring is #16AWg or #14AWG. Don't remember.
When you check go by the copper inside and not the size of the insulation around it. <img src="graemlins/gr_guns.gif" border="0" alt="[guns]" /> <img src="graemlins/burnout.gif" border="0" alt="[Burnout]" /> <img src="graemlins/gr_cheers.gif" border="0" alt="[cheers]" /> <img src="graemlins/gr_devil.gif" border="0" alt="[devil]" /> <img src="graemlins/camaro.gif" border="0" alt="[Chevrolet]" />
That wheelying Z should be orange BTW. <img src="gr_eek2.gif" border="0">
[ January 21, 2002: Message edited by: Rock ]</p>
Old Jan 21, 2002 | 10:56 PM
highgmc's Avatar
how many have left the wires in the orange hose against the header?
how many have lengthened the wires? <img src="graemlins/formula.gif" border="0" alt="[Pontiac]" />
Old Jan 21, 2002 | 11:05 PM
TA_2001's Avatar
I left the factory silver wrap on mine
and put the orange around that. I have not
had any problems but my car rarely sees water
except for wash. I do suggest to any new installs
to double the orange by cutting a unused portion
off near the pcm and installing it where the
wires touch the headers.. again 2000 miles
no problems at all.
Old Jan 22, 2002 | 12:18 AM
WFO_SS's Avatar
i had this problem when i installed mine, the headers started melting the insulation. i cut the wires (i think there's 10 wires) and added about 1 ft to each circuit. i have pictures at home, but i'm computer retarded, i don't know how to get them on here. sorry.
Old Jan 22, 2002 | 02:45 PM
Senior Member
My wires are the stock length inside the heat shielding. Not one problem here. I do drive in the rain and washes and all that good stuff. It does sit right against the header and the headers get really hot when Im sprayin' too. Just dont worry about it.
Old Jan 22, 2002 | 03:22 PM
Skelton's Avatar
Orange wrap here with no problem. It will scorch the wrap but doesn't appear that it will burn through.
Old Jan 23, 2002 | 09:30 PM
ToplessZ's Avatar
Mine also are against the header. Been 3 months and no problems yet. I left the silver tape on it then covered with the orange.
Old Jan 23, 2002 | 09:53 PM
highgmc's Avatar
the y pipe banging was getting annoying so I installed a rubber block between the y pipe and floorpan, now the damn floorpan hums louder and louder as I get on it. GETTING OUT THE SLEDGE TOMORROW to slightly dent in the floor.
Old Jan 24, 2002 | 12:35 AM
horsepower's Avatar
[quote]Originally posted by terry99ta:
<strong>I read on here somewhere that adding to the wires will casue problems with the computer reading a different resistance???</strong><hr></blockquote>
this is incorrect/inaccurate hearsay - lengthening these perticular wires is perfectly acceptable.
Old Jan 24, 2002 | 12:37 AM
horsepower's Avatar
<strong>how many have left the wires in the orange hose against the header?
how many have lengthened the wires? <img src="graemlins/formula.gif" border="0" alt="[Pontiac]" /> </strong><hr></blockquote>
Occasional contact is inevitable, but make sure the wires are not pulled 'tight' against the tubes - this will not work; either because of engine torque or heat or a combo of both.
If you don't want to lengthen the wires, you can carefully 'fish' more wire length out of the main harness from the PCM forward.
Old Jan 24, 2002 | 12:40 AM
I have for more than a year now. At this time I have my motor apart and I'm wraping the wires with two layers of the orange stuff.
Old Jan 24, 2002 | 12:44 AM
Fred 02 WS6's Avatar
<strong>the supplied orange hose it against my header. there seems to be no other way around this other than making the wires longer which I am not trying.</strong><hr></blockquote>
When I did this install on a friend's car, I spent a good hour lengthening the wires from the PCM by tracing them back and taking up all available slack, then rerouting all of the wires through the original looms. The orange wrap still made contact with the header. The smell of oil and possibly the coating on the wrap went away after a day, and he's been driving for 2 months now without any problems. Just make sure the zip ties aren't touching the header and you shouldn't have any problems.
BTW, his car is a daily driver, sees rain and even some snow/salt/sand. No problems to speak of.
Old Jan 24, 2002 | 08:54 AM
horsepower's Avatar
<strong>the y pipe banging was getting annoying so I installed a rubber block between the y pipe and floorpan, now the damn floorpan hums louder and louder as I get on it. GETTING OUT THE SLEDGE TOMORROW to slightly dent in the floor.</strong><hr></blockquote>
you shouldn't need to dent anything (unless you have angle milled heads or something).
2 things to try first:
1 - loosen all the header to head bolts; LS1 manifolds 'pivot' off the center bolt, so you can tilt the headers either up (not good), or down (correct). At the collector, this is worth as much as 1/2 inch drop
2 - loosen all the cat,ypipe, and intermediate pipe torca clamps. Hold the y-pipe down, you can hold it down with a prybar, wood, etc - while you hold it down, tighten all the clamps.
-brian
Old Jan 24, 2002 | 09:01 AM
RPM WS6's Avatar
LS1Tech Administrator
Community Influencer
[quote]Originally posted by horsepower:
<strong>
-brian</strong><hr></blockquote>
Horsepower, I have a question for you. I’ve seen a couple of cases now where the banging is due to the Y-pipe hitting the inside of the driveshaft tunnel (where the floorboard curves up and becomes the DS tunnel) right where the I-pipe and Y-pipe slip together. Is this because of the header being bolted to the head wrong as you describe above? My fix has been to loosen the Y-pipe front and back and pry it away from the DS tunnel, but that fix apparently isn’t permanent anymore as one of them that I did started hitting again. What do you recommend for this? Please let me know. Thanks. <img src="gr_stretch.gif" border="0">
Old Jan 24, 2002 | 11:14 AM
highgmc's Avatar
I have tried to loosen the clamps on the y pipe and cat back while prying down and then tighten them all up but it didn't help at all.
I will try to loosen the drivers side header and tilt it down. I think I can get some that way maybe.
