Max SCR and DCR to be totally safe???
Old Dec 16, 2006 | 12:17 PM
bigdsz's Avatar
Default Max SCR and DCR to be totally safe???
I'm doing a 408 and the machinist told me my combustion chambers were 69cc, so I told him to mill the heads .022", to bring me down to 66cc, which I figured was around 11/1 CR. Well it turns out after I cc'd them myself that the machinist fk'd up, and now after milling they are only 63cc. This puts me at about 11.4/1 SCR and 8.9/1 DCR according to one of the calculators I used. Am I screwed with the CR's I now have to deal with, are they too high for a "safe" engine? Thanks.
Old Dec 16, 2006 | 12:41 PM
03 BUSA's Avatar
For a NA motor you will be fine with a good tune. I have heard of guys with 11:8.1 scr on pump gas with no problems.
Old Dec 16, 2006 | 02:33 PM
slow trap's Avatar
that is a touch on the high side but it is possible to run that high of a dcr on 93,i had 9.0 dcr on stock cubes.what cam are you going to run ? your dcr seems pretty high for 11:4 scr unless it is a pretty small cam on a tight lsa.
Old Dec 16, 2006 | 02:44 PM
bigdsz's Avatar
I've got a Comp XER 244/248 .612/.615 112+2 with a 52* ABDC. I've got -8cc Weiscos going in, Erik@HorsepowerEngineering.com is doing the build, I hope we can go to a -10cc piston to resolve this issue.. It is beyond me how the machinist could make a 3cc error. These heads were not my first choice to begin with, but I need to keep them because of $.
Old Dec 16, 2006 | 02:52 PM
Ferocity02's Avatar
If your running 93 octane or above you will be perfectly fine. You can always go with thicker head gaskets if you want to lower the compression.
Old Dec 16, 2006 | 03:12 PM
bigdsz's Avatar
When I used the CR calculator I used .056 for gasket thickness. I'm using the OEM MLS gaskets, I really don't know the compressed thickness, I've heard .054 to .060. Uncompressed, I miked them out at like .065. If anyone has a better number I'll use it. I was hoping to use a .045 Cometic for abetter quench but that obviously won't work now.
