building a good LS1 out of two bad ones....
Old Jan 22, 2002 | 03:38 PM
Kilroy's 99 TA's Avatar
Default building a good LS1 out of two bad ones....
let's say between two blown engines there's enough good parts to make a single running engine. (block from one, pistons from another...)
assuming all stock parts, how much machining would be required? what parts couldn't be moved due to wear? (for example, I know that the lifters supposedly need to be replaced in the same order they came out, to keep wear even. don't know how much truth there is to this)
assuming this didn't cost much to put together, might it be worth it?
Old Jan 22, 2002 | 03:54 PM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
Default Re: building a good LS1 out of two bad ones....
Do two rights make a wrong? LOL
It's not a bad idea, and I know what shortblock you are thinking of. Depends on the condition of the cylinder walls on that other block, and the condition of the cranks. You would need a usable crank, and block... If that one block has a rod knock then there is a possibility that the crank is messed up just as an FYI.
Old Jan 22, 2002 | 03:58 PM
it would be a matter of 1 part out of 2 would need to be good!!!!!
then I would stuff the whole thing in a Fiero.....
<img src="gr_stretch.gif" border="0">
Old Jan 22, 2002 | 07:37 PM
Matt98SS's Avatar
may cost some small coin to have everything at a machine shop to determine whats good and whats not so consider that into the cost
Old Jan 22, 2002 | 07:51 PM
DóòD's Avatar
[quote]Originally posted by Kilroy's 99 TA:
<strong>it would be a matter of 1 part out of 2 would need to be good!!!!!
<img src="gr_stretch.gif" border="0"> </strong><hr></blockquote>
Do it!! Dump it in a Fiero!!!! <img src="gr_grin.gif" border="0">
I'll be haunting your street to race ya!! <img src="gr_grin.gif" border="0"> <img src="gr_grin.gif" border="0">
Old Jan 23, 2002 | 08:04 AM
Come race me now! I don't need a fiero..... <img src="gr_images/icons/wink.gif" border="0">
Old Jan 23, 2002 | 11:37 AM
DóòD's Avatar
<strong>Come race me now! I don't need a fiero..... <img src="gr_images/icons/wink.gif" border="0"> </strong><hr></blockquote>
After the next snow fall...
Gotta even it up...You still have the blower right!!
Did you ever get your shift points figured out?
(I Know..this was a long time ago...)
Old Jan 23, 2002 | 05:28 PM
So I could have de-assemble everything, see if the block is OK on engine #1, have the crankshafts from both engines & 8 pistons and rods checked, I'd probably get new bearings & rings....
definately have enough pushrods & lifters to reassemble, hope the rockers are good on the heads.
how much do you think it would cost to have a machine shop check the parts out???
I don't want this to get too expensive, but I'm already thinking stronger springs, port the heads, etc... I just don't have a car to throw the engine into....yet.
I'm going to get myself in trouble.
Old Jan 23, 2002 | 05:37 PM
LS1Tech Co-Founder
If the good block still has the crosshatching in the cylinder bores then it's worth doing IMO. I think a few hundos to get stuff checked and partially assembled.
