6.0 liter engine question
Old Jan 24, 2002 | 01:05 AM
RACE-'01 TA's Avatar
Default 6.0 liter engine question
how much do i have to bore a 6.0 iron block to make it a 370ci will i have to re-sleave it? and with some forged 11.0:1 pistons will a thunder racing 224 cam on a 112 be a good cam to go with or maybe a custom grind cam
thanks
-race <img src="gr_images/icons/cool.gif" border="0"> <img src="graemlins/gr_guns.gif" border="0" alt="[guns]" /> <img src="gr_tounge.gif" border="0">
Old Jan 24, 2002 | 08:37 AM
Matt98SS's Avatar
Default Re: 6.0 liter engine question
as far as the cam question...you can go bigger than that in a 370
Old Jan 24, 2002 | 10:08 AM
Crazyquik's Avatar
6.0 liter block bored .030 will be 369 ci. I'd go with a bigger cam than that.
J.
Old Jan 24, 2002 | 10:28 AM
CHRISPY's Avatar
You can go with a .060 overbore in a 6 liter iron block. That will give 375 cubic inch.
However the weight penalty will outweight the Hp gains IMO. A good heads and cam package will dyno about 15RWHP and 20RWTQ less but you also have 75 pounds less weight to move.
Cheers,
Chris
Old Jan 24, 2002 | 11:02 AM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
There are a lot of .030 and .040 setups out there, some .060's like mine, and I have only read of one .080 setup.
Weight difference is 65-70lbs, but the potential is there for a cheap big bore motor.
