LS1 coldair install help
Old Jan 27, 2002 | 11:51 AM
matler23's Avatar
Default LS1 coldair install help
I am trying to install a LS1 coldair system that I bought from tbyrne. I am trying to remove the air deflector panel in front of the AC condensing coil and I can't seem to find the last 2 clips. I was able to remove the two "turn" clips on each side of the hood latch, but I can 't find the others <img src="images/icons/confused.gif" border="0">
Thanks!!
Old Jan 27, 2002 | 11:36 PM
Gearhead's Avatar
Default Re: LS1 coldair install help
Not sure how your system is, but we installed the Fast Toys RA on the '99. The other clips I think you are referring to are near the side tanks of the radiator, on the front-side of the radiator. We got them out by pushing on the black deflector, pushing to the front of the car. If you run your hand up and down the deflector near the radiator tanks, you'll feel a recessed "pocket" which is where the clip (one on each side) is located. Try to push from there. They were a little tough to get out, but pop back in real easily. Hope this helps.
