Equus temp. adapter broke off in the cyl. head!!
-Josh
Go freeze plug! <img src="gr_stretch.gif" border="0">
Dope
same as the one directly below the oil
filler tube on the front side of the pass
side head??
If there is on on the back that you have talked
about how do you get it out.. I know once we
talked about it being threaded but the one
in the front seems pressed in ??
Dope give us a proceedure .. Im ready to try it.
Terry ( got my fan mod switch in this weekend )
Dope
you get the freeze plug out, the one direcly
above the starter ??
I wish I would have thought of all of this when
I was puting in the slp lt's in november.
tia
Terry
I also installed an Oil pressure sending unit on the housing that is on top of the oil filter. First you have to remove the CAT then unbolt the two bolts holding the housing on. Oil will come down so have bowl ready. Drill and tap the housing. The oil pressure sending unit was a 1/8th tap. The housing is aluminum so it drills and taps easily. Anyways good luck.
So I don't have any other solutions for ya, sorry <img src="gr_images/icons/wink.gif" border="0">
Dope
<img src="graemlins/gr_cheers.gif" border="0" alt="[cheers]" />
[ January 28, 2002: Message edited by: Plum Crazy Rob ]</p>
The one you spoke of, above the filter, by the cat, is the stock sending for the oil temp gauge on Corvettes. Are there any other plugs that have access to oil passages?
Dope
