Any benefit with going with a higher lift?
As an example, there is the Comp cam 218/218.
IWas wondering if there any benefit with going with a higher lift on the Comp 218/218 cam with stock heads? I was looking at one with a lift of .562/.562. Also, seen them with a .527/.527 lift. Wouldn't the higher lift just cause more valvetrain noise and more stress on the springs? Thanks...
Is it worth it? Depends on whether you are trying to squeeze the last bit of power out at a given cam size versus noise and spring longevity.
