Those who installed SLP fan Switch???
Old Jan 29, 2002 | 10:58 PM
2001Z28's Avatar
Default Those who installed SLP fan Switch???
After you plugged the connectors in the harness in the engine bay, Where did you route the wires to get into the car. And also how did yoiu do this. If anyone could help it would be a great help.
Old Jan 29, 2002 | 11:18 PM
TA_2001's Avatar
Default Re: Those who installed SLP fan Switch???
take out or move over the pcm. Down there
is a rubber grommet that you can go around
or through. On my car it seemed to be attached
to the wire harness going through it. I went under
it with a small wire then put it back. To get to
the inside take down the two push pins under
the glove box then you may need to take out the
kick panel and rail by the door , 4 screws.. then
you can see the grommet up in there. I used a coat
hanger as a guide.
Old Jan 30, 2002 | 09:32 AM
Trevor @ Texas Speed & Perf.'s Avatar
LS1Tech Premium Sponsor
Active Streak: 30 Days
Active Streak: 60 Days
I did what TA_2001 did. I taped the wiring to a coat hanger and pushed it through the hole in the firewall on the pass. side. I pulled the rubber grommet back to run the wire through, and I went from the inside and ran it into the engine compartment. As TA_2001 said, you'll have to pull the kick panel off under the dash. It has two push pins that you can pull out with a pair of needle-nose pliers. I ran the switch into my ash tray and mounted it to the side of the ash tray. I had to trim the plastic some, but it looks great.
__________________
