About Rods ..... can you help ?? its simple
Old Jan 30, 2002 | 07:59 PM
Abdulla's Avatar
Default About Rods ..... can you help ?? its simple
Ho all <img src="gr_stretch.gif" border="0">
do you have any idea...if i am using my stock ci, the leangth of the rods should be what, and that if i am replacing it with aftermarket one
what about 6.125 oliver or crower billet rods ?
is the length good or not.. ? because i am gona use really big cam
and what kind of pistens should i use...to give clearness to the valves ??
Thanks in advance <img src="gr_stretch.gif" border="0">
Old Jan 30, 2002 | 08:48 PM
Abdulla's Avatar
Default Re: About Rods ..... can you help ?? its simple
ttt
Old Jan 31, 2002 | 11:07 AM
Fireball's Avatar
6.125 rod but you need a piston spec'ed out to that rod length
Old Jan 31, 2002 | 11:54 AM
steve's Avatar
stock rod is 6.090
once you decide what rod you use thats is when you need to figure out what compression height for the piston.
steve frank
Old Jan 31, 2002 | 01:53 PM
Jason99T/A's Avatar
I can shift faster than you.
Abdulla, did something happen to your motor? How is the new heads/cam combo doing?
Old Jan 31, 2002 | 06:27 PM
LS1derfull's Avatar
Abdulla, keep in mind longer rods will sometimes need deeper valve reliefs to maintain piston to valve clearance. I still think they are a good idea.
