Exhaust primary tube temps.
Old Feb 1, 2002 | 06:25 PM
ProModTA's Avatar
Default Exhaust primary tube temps.
Here latley I have developed a idle stumble and have been trying to find the problem. Today I checked the temps of the header tube temps at the flange area just before the bend and all but one was around 220 degrees. The #2 cylinder was at 346 degrees. Could this cylinder be running to lean causing the idle stumble/miss? Im kinda thing this could be the problem.
Doug
Old Feb 2, 2002 | 09:25 AM
99WhiteSS's Avatar
Default Re: Exhaust primary tube temps.
Yes, lean conditions will not allow unspent fuel to carry the heat produced out of the cylinder. The result in higher exhaust/header temperatures. You may want to verify that the #2 fuel injector is operating correctly since this seems to be an isolated case. Simply running some fuel injector cleaner with your next tank of gas may help solve your problem.
-Kris
Old Feb 3, 2002 | 05:49 AM
ProModTA's Avatar
Thanks for the info. I was thinking thats what it was but wanted to make sure.
Doug
