What can I expect From this?
Old Feb 3, 2002 | 09:34 PM
Bob99Z28's Avatar
Default What can I expect From this?
Hello,
My first post here. Anyways, I got some money comin back from taxes here in a few days, and i want a ram air 2 hood...but i got about $1200 left over. I was wondering, would it be ok, and what can i expect to gain....if I do a cam and a LS6 Manifold on my car with the mods I have?? Lets assume I have Long Tube headers and a cut out or loudmouth or something (got those covered too). What kind of HP should i see (I am concerned about not having the heads done). Should I wait and save up the money for the heads and do them all at once or can i do cam and manifold and be ok?
Also, Do i need anything else like MAF and ported ends if i do these things?
Thanks in advance.
[ February 03, 2002: Message edited by: Bob99Z28 ]</p>
Old Feb 4, 2002 | 09:18 AM
Nine Ball's Avatar
LS1Tech Co-Founder
Default Re: What can I expect From this?
99 Z28 with:
Lid + Holley Filter
Yank ST-3500
FTRA
Cam (B1 for example)
LS6 intake
Longtube headers
cutout
I'd estimate around 350-360 rwhp with your A4 car and these modifications. With the right launch on slicks and about 3500 lbs raceweight you should see high 11s no problem.
Welcome to the site!
Tony
Old Feb 4, 2002 | 10:18 AM
Bob99Z28's Avatar
Very Sweet Tony. Thats what I wanted to hear. My goal inlife is a 11.5's or lower on motor, and it seems from what you said if i get my heads done i should be there (after these mods). Then i can spray my way to the 10's.
Question for the mods i was asking about....do i need a new maf or ported throttle body? Or do the heads dictate that? In other words, can i wait till i get the heads done to get a maf and tb or do i need them with the cam and maifold?
Old Feb 4, 2002 | 11:44 AM
Nine Ball's Avatar
LS1Tech Co-Founder
You can use the HPP3 to change your shift points (you will be shifting at 6500-6600 with a good cam). You can use a ported stock MAF and a MAF-T to adjust your air/fuel mixture, but the proper way to do this would be to purchase LS1-EDIT software (about $450) for your '99 car and handle things more accurately.
With LS1-EDIT, you can get rid of the HPP3 also.
11.50s with heads/cam/bolt-ons and A4/converter should be no problem if you can hook.
Tony
Old Feb 4, 2002 | 01:10 PM
Nine Ball's Avatar
LS1Tech Co-Founder
check out our Computer programming section for LS1-EDIT info. It just was made available.
MAF-Translator plugs in between the MAF and the harness going to it. It has two ***** to adjust, basically tricking the PCM into thinking the MAF is sending different info.
No, your car will not shift where it needs to with just a cam swap. The electronic controlled tranny needs to be told what to do.
Tony
Old Feb 4, 2002 | 02:05 PM
Bob99Z28's Avatar
Thanks Tony, I really Appreciate the info you have given me, saved me some headaches i am sure.
Thanks again.
Old Feb 5, 2002 | 12:23 AM
Bob99Z28's Avatar
Tony, Thanks again.
So this LS1-edit is a software program or something? Where can I get it? Also, where can I get a MAF-T (translator i assume)? It just plugs in and does its thing? Also, you mention shift points....if I change the cam without changing the shift points...the car waont shift where it needs too? I had a 85 Trans am with a nice cam in it, shifted about 6500...but there was no computer changing neded for that, there is now?
