Fuel system with return line worth it?
Old Feb 4, 2002 | 04:29 PM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
Default Fuel system with return line worth it?
Anyone?
If you have an ajustable regulator will the pcm just override it?
Old Feb 4, 2002 | 04:51 PM
ToplessTexan's Avatar
Default Re: Fuel system with return line worth it?
Changes the pulse width while in closed loop. You should still be able to pull fuel at WOT by reducing pressure though.
Old Feb 4, 2002 | 06:32 PM
Colonel's Avatar
I think one of the reasons that my FP drops back so much at WOT is because the FP regulator is at the tank instead of the rail.
Old Feb 4, 2002 | 08:01 PM
Tim98TA's Avatar
From: From the Bowels of Hell!!! You want some of me bitch?!?!?!
[quote]Originally posted by Colonel:
<strong>I think one of the reasons that my FP drops back so much at WOT is because the FP regulator is at the tank instead of the rail.</strong><hr></blockquote>
Check with ARE. I think they have that problem solved with a new setup.
Tim
Old Feb 4, 2002 | 08:11 PM
A70camaro's Avatar
Main reason that GM started using a returnless
fuel system is to keep the fuel from heating up
because of the engine heated fuel returning to the tank.
Only thing is you need a hell of a fuel pump to keep up with the demand on a returnless system
on a high hp engine.
If your makin power and loosing fuel pressure
fabricate a return line with a rail mounted
regulator . I think a AN6 line will be big enough
for the feed and use the old steel line for your return making the necessary mods of course.
Also keeps the fuel line from pulsating .
Old Feb 5, 2002 | 08:11 AM
Colonel's Avatar
My new fuel system will be Speed Inc's billet fuel rail, their rail mounted regulator, 8AN line in, 6AN line return. It'll have my present remote FP gauge on the driver's side rail and a rail mounted gauge on the passenger's side rail. <img src="gr_images/icons/cool.gif" border="0">
