Need help with Texas speed package!
Old Dec 26, 2006 | 09:25 PM
dazman's Avatar
Default Need help with Texas speed package!
ok, i have finally found what i want...
97' corvette
-ms4 on a 110 lsa with their spring kit and push rods-
-ls2 timing chain
-tsp headers with x pipe
-loud mouth w/no cats
-tsp tune
-gasket kit
-ram clutch. master cylinder and slave
-o2 sims (do i need these if im getting it tuned???)( i have obdII here )
car already has
-ls6 intake
-pulleys
-oil pump
do i need to know anything else???
my goal is to have a nasty street car that is driven 2 nights per week.
Old Dec 26, 2006 | 10:11 PM
03 BUSA's Avatar
As far as the 02 sims go, if you are getting a tune, you can just have them turned off by TSP. Everything else looks good, I would just look at a set of heads. TSP is the right company to go with, good luck with everything.
Old Dec 26, 2006 | 10:43 PM
camarokid94's Avatar
i agree get there heads too. just get one of there H/C packages good invesment.
heads will really help in your goal. also you prolly gonna need GEARS and if its an auto a STALL
Old Dec 27, 2006 | 08:05 AM
YellowToy/A's Avatar
i would get Qtp or kooks headers
Old Dec 27, 2006 | 08:24 AM
dazman's Avatar
i had a friend have his car done and they blocked the 02 sensors and it would not pass obdII, have yall heard of this??
car is manual-
and have you ever heard of the ram clutch? i have only used spec in the past
mike
Old Dec 27, 2006 | 01:48 PM
Jefro6996's Avatar
I would call TSP and make sure that cam fits on a 110. I think it should since you have stock heads, but I would make sure.
Old Dec 27, 2006 | 09:48 PM
dazman's Avatar
hell ive been trying to call texas speed for three days, they are always out to lunch or busy ( phone busy ) im going to try to keep calling tommarow, ive got credit card in hand ready to buy
mike
Old Dec 28, 2006 | 06:57 PM
Gannet's Avatar
Does this car have to pass smog inspections? If so, the MS4 would seem a bit much.
Old Dec 28, 2006 | 09:41 PM
dazman's Avatar
no, its just obdII
dazman's Avatar
what will the tighter lsa do for the car 111 vs 110???
Old Dec 29, 2006 | 10:39 PM
Gannet's Avatar
They are both very close. The 111 will push the peak RPM up a hair and have a hair lower DCR.
Really, for a car with a stock shortblock, I think this is less than an ideal choice. The DCR is quite low. I get 7.84:1 with my version of the DCR spreadsheet. Assuming a 4 degree cam advance, the .050 IVC is at 45.5 degrees. That's going to put ideal shift point up around 7000 rpm. I would at least get heads with smaller chambers to pull up the compression. But then you may get into PtoV clearance issues and have to flycut.
Unless this is purely a track car, I'd go a couple notches smaller.
Old Dec 30, 2006 | 07:16 AM
Hardtop's Avatar
I'd add a set of ear plugs to that list. A loudmouth with an ORYP is going to be too damn loud IMHO.
Bruce
Old Dec 30, 2006 | 07:45 AM
WKMCD's Avatar
Bruce
You got a point...
Also, you don't need sims. Just get them tuned out.
Old Dec 30, 2006 | 08:30 AM
bad95killer's Avatar
I'm quite sure Jason or Zach from TSP mentioned that in other thread the 110LSA required Flycutting with stock heads .
peace
Old Dec 30, 2006 | 09:11 AM
cws T/A's Avatar
MS4 is 111+1 From what I read from TSP
IVO 9.5 .. IVC 49.5
EVO 53.0.. EVC 9.0
So cam only LS1 it has 7.5:1 DCR .055 gasket / 67cc
and cam only LS6 it has 7.8:1 DCR .055 gasket / 64cc
If a .040 thickness headgasket clears with out valve notches the numbers will be better.
If you want badass horspower/torque #'s you'll need to get the DCR in the 8.5-8.8 range . Which will take the static compression to the 11.5:1-12.0:1 range for this particular camshaft .
It needs small chambers to fully appreciate which will require piston notching . Well worth the power gain though .
See what I mean here .. https://ls1tech.com/forums/dynamometer-results-comparisons/539900-480rwhp-magic-stick-4-camshaft-prc-stage-2-5-ls6-fast-90-resullts.html
The compression makes a difference people. What would you run 440rwhp not having to flycut, stock range combustion chamber, not optimal compression , it bolts right together or 480+rwhp , pistons flycutt ,Heads milled , compression optimal , more work but No pain No gain. Do it once and do it right . Wheres my angle drill goshdarnit
