Oil what kind!
Short skirt pistons + low tension rings = power & oil usage I guess. Kinda like in body building you gotta gain a LITTLE fat at the least if you are bulking for muscle.
As I mentioned, I am switching to Pennzoil Platinum and will be using their 5w30. I can't say for sure how it's going to do in terms of engine wear or oil consumption but I'll be sure to post my results here once I get them. This oil has been showing very good oil analysis results in many different vehicles, and currently there are a lot of places selling it for a killer price (I've seen as low as 99 cents a quart after rebate)
This oil is very hard to find, and I don't know anyone who is running it. If you can find it, by all means give it a try, but get an oil analysis done after you've run it for a while, and see how it's performing.
Whatever oil you guys choose, I highly recommend getting an oil analysis done, as it will often help you eliminate other problems, such as an air intake leak (which would show up as having too much silicon-or dirt, in your oil)
