What Brand Oil's Are You Using
Old Dec 29, 2006 | 02:31 PM
Whitez406's Avatar
Default What Brand Oil's Are You Using
Im curious im running mobil 1 5w30 syn, mobil 1 syn atf, and mobil 1 syn 75w90. Im thinking of switching over to royal purple in everything. Just curious what brands and weight oils your running. Thanks
Old Dec 29, 2006 | 02:40 PM
brady346's Avatar
bolt on car-111k miles
Mobil 1 0W40, cheapest tranny fluid available, whatever came in the rearend from the factory.
50+ psi oil pressure @ 2400 rpm highway cruising speed but not too high on cold start
Old Dec 29, 2006 | 03:52 PM
1fast01's Avatar
mobil 1 0W40...383 stroker
Old Dec 29, 2006 | 04:16 PM
MeentSS02's Avatar
Kleeborp the Moderator™
Amsoil 5w40 in the engine, Torco ATF in the transmission, and currently Mobil 1 in the rear. My new Strange 12-bolt will have Torco RGO when it gets installed.
Old Dec 29, 2006 | 04:46 PM
JPH's Avatar
JPH
royal purple oils here.
Old Dec 29, 2006 | 04:50 PM
Bluewire's Avatar
Amsoil all around.
Old Dec 29, 2006 | 05:44 PM
Whitez406's Avatar
I think im gonna switch to royal purple in everything this winter. 0w40 just sounds scary but ive heard only good about it. Anyone had any problems wiht any oil brands?
Meent how are the torco oils?
Old Dec 29, 2006 | 05:52 PM
vettenuts's Avatar
German Castrol 0W-30, best oil analysis I have gotten is from this oil.
Old Dec 29, 2006 | 08:49 PM
TXZ28LS1's Avatar
castrol syntec 5w-40 for the engine and castrol atf dex 3 for the tranny!!
Old Dec 29, 2006 | 08:57 PM
1cleanbird's Avatar
castrol syntec 10w30, but next time royal purple.
Old Dec 29, 2006 | 09:42 PM
Blktie8's Avatar
Default Amsoil Here
Originally Posted by Bluewire
Amsoil all around.
Amsoil 10-30 The new amsoil trans fluid for a4 quick shift(Not sure of the name ) amsoil 75-90 In the rear gears
c5 corvette
Old Dec 29, 2006 | 10:06 PM
Killer_Bluebird's Avatar
Engine: Royal Purple 5w30 (before Mobil 1)
Tranny: Royal Purple Synchromax 10W
Rear End: Redline Heavy ShockProof Gear Oil 75W90
Old Dec 29, 2006 | 11:45 PM
1999ssls1's Avatar
Old Dec 30, 2006 | 12:37 AM
00454sscamaro's Avatar
royal purple 10w 30-engine. rp--?(forget exact weight/name) in the rear, and got rp syncromesh waiting to go in the t56 next time i have the shifter out. couldnt be happier with the switch from previous m1.
Old Dec 30, 2006 | 01:33 AM
BLKWS.6's Avatar
A secret and magical blend of herbs and spices! (imported from Germany by Castrol.)
Old Dec 30, 2006 | 01:36 AM
matts22's Avatar
haha, ditto on that...I guess...
Old Dec 30, 2006 | 01:52 AM
BLKWS.6's Avatar
Oh...and in the T56 I run Valvoline Dexron III/Mercon dino and in the rear 85/140 RP w/the GM addative too (I have a Torsen, so it wont "slip too much" or anything)
Old Dec 30, 2006 | 02:00 AM
RPM WS6's Avatar
LS1Tech Administrator
Community Influencer
Engine: M1 0W40
Trans: Valvoline DexIII (dino)
Rear: GM/Goodwrench 80W90 (dino) + GM additive
No complaints with any, no plans to try anything different.
Old Dec 30, 2006 | 02:13 AM
00T\A's Avatar
Valvoline everywhere.
Syntech in the motor of coarse
Old Dec 30, 2006 | 05:33 AM
DaddySS's Avatar
Castrol 0w 30 in the engine and castrol for all other fluids except dexcool in the cooling system.
