Which of these Parts/where to buy
Old Feb 11, 2002 | 07:51 PM
Nocturnal-TA's Avatar
Default Which of these Parts/where to buy
what up guys, usually hang out at ls1.com but nobody their wants to answer this particular question so I decided to do some slumming. <img src="gr_images/icons/wink.gif" border="0"> j/k anyway here are my questions. thanks in advance
Which timing chain/ oil pump to buy
Putting together a hotcam "kit" have the cam, just need the other stuff.
1)Got the springs and seats covered. Will the comp cams steel retainors work with the ls6 springs?
2)are valve keepers and valve spring seats the same thing?
3)Also want to upgrade my oil pump. The ARE number is pretty pricy, is the stock ls6 pump a good choice?
4)Also want to pickup a timing chain. The double roller sounds good, comp cams has a new one but I have heard it is not a true double roller??
Help is appreciated, this money is begging to be spent.
__________________
98 T/A Black M6 T-top
!FRA Descreened MAF !EGR !Battery Relocate
Loudmouth, MTI LID
KVR Cross Drilled Rotors, Ceramic Pads
Alpine CDA 7873 Head Unit, Polk EX Front Component /Mid Speakers,
JL stealth Audio Box 10w30 sub, Alpine MRV7757, Brown Bread
[ February 11, 2002: Message edited by: Cybertech ]</p>
Old Feb 11, 2002 | 08:03 PM
SuperCamaroSS's Avatar
Default Re: Which of these Parts/where to buy
look through Speed inc's website. www.ls1speed.com
Old Feb 12, 2002 | 09:53 AM
blackhawk2000's Avatar
I'm sure one of the sponsors you trust would have the answers you seek.
Old Feb 12, 2002 | 10:04 AM
Nine Ball's Avatar
LS1Tech Co-Founder
Maybe nobody on the other site answered your questions because they didn't know the answers? <img src="gr_images/icons/wink.gif" border="0">
1. Don't use the LS6 springs. Invest in some Comp 26918 springs, which use the stock retainers no problem. If you are going to upgrade springs, might as well get the better ones and do it right.
2. Valve keepers and spring seats are not the same thing. Valve keepers are the locks that fit into the top of the retainers that hold the valve stem groove. Spring seats sit underneath the valvesprings on the head surface.
3. Get a modified stock oil pump from one of our sponsors. ARE, Cartek, MTI, MMS, Thunder should all have them available. Basically they are ported slightly for better flow and the relief valve is shimmed so that they hold more pressure before bleeding off.
4. Stock timing chain is okay, and the only better upgrade is the C5-R timing chain which is about $140 I believe. Many, many cars are making over 500+ rwhp with the stock chain. I've only run stock chains on my setups.
Feel free to post your TECH questions on this site FIRST next time <img src="gr_images/icons/wink.gif" border="0">
Tony
Old Feb 13, 2002 | 01:02 PM
ok, so no ls6 springs, stock retainors and timing chain. get upgraded oil pump. Is there anything else I will need for this installation? thanks for the info. I will have to come by more often <img src="gr_images/icons/wink.gif" border="0">
