why is my cam sproket so close to......
Old Dec 29, 2006 | 06:59 PM
erikthegoalie's Avatar
Question why is my cam sproket so close to......
i installed a cam, and when i put the retainer and its bolts back in and moved to the sproket, I noticed that the sproket is VERY close to the heads of the retainer bolts....i was 100% sure I used the correct bolts...the chain and sproket spin freely, no hittings or anything..I am just making sure...it looked dam close, BTW i torqued exactly to what HOWTO said...
Thanks
Erik
Old Dec 29, 2006 | 07:03 PM
SScott236's Avatar
Mine was like too so I think its okay(I hope). Its not actually hitting is it?
Old Dec 29, 2006 | 07:12 PM
JPH's Avatar
JPH
it's close for sure. are you using an aftermarket dbl. row chain set up?
Old Dec 29, 2006 | 07:18 PM
no it clears 100% i turned the engine over many times to make sure...even removed and reinstalled...its just close...eeeek
I am running stock sproket/ ls2 chain.....not Dub. roller
any thoughts? im sure its fine...i think just about everything on this build has gotten me woried...eventhough nothing major has gone wrong
Old Dec 29, 2006 | 07:22 PM
JPH's Avatar
JPH
your fine. take a paper clip, strech it out and see how close the head of the bolt is to the back of the cam sprocket. then measure the paper clip thickness.
