01's ticking? http://s99.photobucket.com/albums/l2...torvids006.flv Here is a vid of my friend's 01 SS. I have an 01 WS6 and I have researched it a lot and on most 01's this sound is pretty prevalent. The other years dont have it? Why? Is it b/c the new lifter design in 01 or do our cars have a problem or what? (LIGHT RAPID tapping on decel from a rev, taps from like 1800-1200 on decel). I have put 5K miles on my car and she pulls/runs fine, jsut curious if its the new lifter or what that does it in 01s? |
Yeh that is with the camera really close to the motor so its not even that loud but it is there as u can tell. |
Can't hear it very well from the video but does it only do it on decel? That would tend to indicate that it is not a lifter. |
On decel 1800-1200rpms, a lot of 01 cars do this, mine does it exactly like the one in the vid and there was another vid floating around here that was the same as well. |
We the only 2 here that have this? |
No look at all the 01 cars in this thread. https://ls1tech.com/forums/general-maintenance-repairs/602275-lifters.html |
That doesnt sound right at all its like a bad ticking mine doesnt make a noise like that but it makes it own little ones but its a beast. |
Mine ticks like that too...I changed pushrods thinking that was the problem, not the case. I had someone tell me that it sounded like fuel injector ticks, but im really not sure now. |
Mine sounds like a 350hp sewing machine on decel or very light acceleration in the same approximate rpm range. I would be willing to bet mine is pushrod related since its stock and has BANGED a 6500 rpm rev limit several times. |
i have an 02 and it ticks, when i crank it up from a cold start, and then with a little rev it does it on decel, but if i rev it alot or after the motor warms up it goes away, someone told me it was the timing chain, it makes noise until it gets lube properly or something, i don't know if they were right, just tryin to help out |
What is the month of manufacture? In March of 01 (from memory) GM switched to the coated pistons to quiet them down because of consumer complaints. |
Shit I think mine was made in october of 2000. |
I dont think this is pistons. |
No its not but still sucks u know lol. |
Originally Posted by SpdFrk1990 No its not but still sucks u know lol. I jsut wanna see if others have it. If enough ppl do and have high miles on their car with it not causing an issue and having been there its whole life, ect. then I will consider it normal, you know? |
Originally Posted by TwistedSS Mine ticks like that too...I changed pushrods thinking that was the problem, not the case. I had someone tell me that it sounded like fuel injector ticks, but im really not sure now. |
Well you know its normal there is alot of threads about it. |
| All times are GMT -5. The time now is 01:07 AM. |
© 2026 MH Sub I, LLC dba Internet Brands
